-   -   CSA 2010 - An example (https://www.classadrivers.com/forum/rules-regulations-dac-oh-my/39401-csa-2010-example.html)
Twilight Flyer 01-21-2010 08:51 AM
So here you are, a safe driver. You've been on the road for years, you've got over a million accident-free miles and you're working on your 2nd million. You've got no tickets, you're a defensive driver, and your a multiple-time driver-of-the-month and driver-of-the-year for your company. You are absolutely the driver that EVERYONE wants to hire.
With me so far?
Good.
It's a bright, sunshiney day. Beautiful day for you to haul that Wal Mart drop and hook load. You are cruising on down the interstate, driving safely in the right lane, listening to a good XM station, singing along to your favorite song. You know, all is just plain right with the world.
Suddenly, a car comes barrelling off the on ramp and cuts right in front of you and slams on his brakes because he's a drunk d0uchebag arguing with his drunk girlfriend who is screaming at him from the back seat of their ratted out little one-lung putt-putt piece of crap car! You do a hard brake to avoid planting this tool and his woman 6 feet under and you silently breath a sigh of relief and mumble a quick prayer of thanks that you were aware enough to avoid the accident. However, somewhere within your loaded trailer, several pallets shifted and a case of of grape juice tumbles over, breaking one of the bottles.
You, being the knowledgable driver that you are, make for the very next exit, which happens to be the scale house, so you can fix whatever problems the idiot tool caused you.
On comes Mr. Officer who proceeds to break the seal on your load and do an inspection on loading and securement. He finds that your load has shifted (10 points), your load is not secure (10 points) since it obviously shifted, and of course, you have leakage with the broken grape juice bottle (10 points). So already, you have 30 points in less than a minute.
Happily, you can only be tagged for 3 things per inspection. So you're off the hook on failing to prevent cargo spilling (10 points), failure to re-examine your cargo and load during transportation (10 points, since it must be done withing 50 miles of beginning your run), improper weight distribution since the load shifted and put you over on your drives (7 points), insufficient means to prevent forward movement of said freight (10 points) --
Time out for a second...do you know if you have a load of bowling balls and one comes out of a box and is rolling around on the trailer floor, there are 4 different freight movement violations for that? Insufficient means to prevent forward, rearward, lateral, and vertical movement. Four different ways, 10 points each. No, I am not joking.
-- onward. Vehicle not equiped against vertical movement, since your load is shrink wrapped pallets (10 points), pre-loaded and sealed, cargo not immobilized or secured (10 points), and several others than can be easily and subjectively used to knock you down.
So, with ALL of that, you luckily get smacked with only 30 points because of the tool that jammed in front of you and is now long gone down the highway to kill some unsuspecting mother and her 4 children in a headon collision with her minivan.
But wait! Not so fast! We forgot to talk about the multiplier system. Can't forget about that. The multiplier system? Oh, that's nothing big...it simply means that all points that you've 'earned' in 180 days is given a multiplier of 3. Points between 180 and 365 days is a multiplier of 2. And points between the 365 days and 18 months is only a multiplier of 1, with anything over 18 months dropping off.
So your 30 points just became 90 points. And at that amount, we'll see that topped off with a 2 (X3) = 6 point violation for being put out of service until your cargo issues are fixed.
So there you have it...96 points for this one instance and you're out of service. And since the company gets to share in your points, what do you think the odds are of you keeping your job? Or getting another one after you are instantly fired.
CSA2010...there for your safety, baby!
:roll:
BTW, since CSA is all about safety, can anyone explain how a Log Violation (general/form and manner) is worth 2 points (6 when you factor in the multiplier). Yes, what that means is that if you forget to put your pro# on your log book, you're busted. Of course, we know that failure to do that is certainly a safety issue and puts every motorist on the roads that day at much greater risk.
mike3fan 01-22-2010 08:20 AM
The sky is falling!!!!!!!!!!
Twilight Flyer 01-22-2010 08:54 AM
'Tongue in cheek' or not, drivers are screwed. One of the biggest concerns of this CSA 2010 is its subjectivity and zero recourse for a driver. And CSA 2010 is EXACTLY that. Companies, of course, have recourse. They will simply fire the drivers during the intervention phase and all will be right with the world...until they need to hire another one.
But drivers? All I can say is that you better mind your P's and Q's and hope you don't meet up with a DOT officer having a bad day. And for pete's sake, stay away from the Banning scales! :thumbsdown:
dieselgrl 01-22-2010 10:16 AM
Playing Devil's advocate for a moment here, but van and reefer drivers are held to the same standards that flatbed drivers are for proper bracing and securing of the load, it's just not nearly as visible. This means that the driver in your above scenario failed to properly secure his load because if it had been examined, he could have used load locks, van straps or bracing material to prevent the cargo from shifting when he was cut off. The only issue I have with this scenario is if you were to say he picked up a pre-loaded and pre-sealed trailer, thereby preventing him from properly securing the load. As written, even though I agree that the car was the d0uchebag, the truck driver wasn't totally without fault either due to the securement side.
ETA - I just reread the original post and I see where you specify Walmart D/H. Carry on, I'll be quiet ;)
Twilight Flyer 01-22-2010 10:22 AM
:thumbsup:
Which is another BIG issue that the DOT seems unwilling or unable to answer. What happens when the driver picks up that load? Does he break the seal to check it? And what then happens with the liability of the load integrity? Oh, a Wal Mart employee accompanies the driver on the check and then reseals it? Great. What happens if it's a relay? Gonna have that Wal Mart employee going with the driver on that run?
Implementation of the CSA 2010 is going to be an absolute, total clusterfart. :micro:
Ridge Runner 01-22-2010 12:20 PM
Why does WM not do what we do? We ( the spotter ) puts the seal in the door handle or in the back of the trailer and then drops it on the yard. No excuse for not inspecting the load. Also if the seal is missing or lost or broken then the guard issues another one and signs paperwork reflecting the new seal number. ???
allan5oh 01-22-2010 12:45 PM
The FMCSA has come out saying there are many myths about CSA2010, and the point system is very much part of it.
The most important thing to remember(this comes STRAIGHT from FMCSA's mouth) is that the points are not weighted equally. There are 7 different "buckets" where points are assigned, and you can only compare points in the same bucket.
From there each carrier is put in a peer group of carriers of similar size etc... Only then a percentile is assigned to each carrier for each of the 7 "buckets".
So one carrier with 50 points in a certain bucket might be in the 35th percentile(satisfactory) and another carrier with 35 points might be put in the 85th percentile(yikes!).
bentstrider 01-22-2010 02:37 PM
Just mores ways to get people fired and into a bread/unemployment/college counseling/ any type of line.
The girly lawyers that make all of these laws up have never ventured out into the countryside and would rather remain safe in their urban strongholds.
Oh well, guess that just means we'll have to do as the above poster said about minding the P's and Q's, which basically means any vehicle out there is a potential force to be reckoned with.
Can't wait to be able to get back out there and get a taste of this new fruit.
I reckon it'll be a "bit nutty".
headborg 01-22-2010 03:33 PM
yeah, but playing "Devil's Advocate myself... it's always been the DRIVER's Right & Responsibility to inspect EVERY load they haul.. shipper sealed or not.. (unless it's a Government SEAL.) the shipper is required to reseal it before you leave the property.
And any driver that would pull into a scale house to Inspect their load after a hard brake-- is kinda dumb in my book. The oldest rule still applies.. never stop at a scale.. piss your pants first, soil your undies. but don't go looking for trouble.. and they say "Safe Haven" it's ok to park here overnight .. we won't bother you. Yeah right!
Twilight Flyer 01-23-2010 02:28 AM
No myth about the points. What I posted is verbatim out of the Cargo-related bucket.
Correct. There are 7 buckets, as follows.
Unsafe Driving
Fatigued Driving (Hours of Service)
Driver Fitness
Controlled Substance/Alcohol
Vehicle Maintenance
Cargo-related
Crash Indicator
And you are also correct in that points comparisons can only be compared from the same buckets. But that is with carriers only. Drivers are simply the company liability and drivers with a lot of points are not going to have a job for very long. Company gets rid of a driver with points, that qualifies for their intervention reaction and the company points go down. Driver, though, gets to keep his points, including the multipliers, for 18 months.
There is also a difference in carrier liability and driver liability, meaning that a carrier can get hit with points on an inspection and the driver be OK. Let's take a look at those buckets again.
Unsafe Driving -- 15 out of 16 are driver responsibility
Fatigued Driving (Hours of Service) -- 3 out of 3 are driver responsibility
Driver Fitness -- 15 out of 15 are driver responsibility
Controlled Substance/Alcohol -- 9 out of 11 are driver responsibility
Vehicle Maintenance -- 11 out of 13 are driver responsibility
Cargo-related -- 50 out ot 50 are driver responsibility
Crash Indicator -- subjective...no specific violations, but is actually based on driver history and patterns of high crash involvement. So it will all be on the driver.
So, 103 out of 108 potential violations are solely the driver responsibility, including ALL of the FIFTY cargo-related ones, of which I based my example solely on. Again, the difference in the carriers and drivers is that a carrier can eliminate a driver, thus eliminating the points. The driver cannot do that...he/she is stuck with those points and their multiplyer through the 18 months.
That makes it really hard to keep a job and even harder to get a new job because a new company that hires a driver, automatically inherits whatever points the driver currently has.
Look, I see and understand what the CSA 2010 is supposed to accomplish and I'm all for more safety on the roads. But the implementation and even the entire design of this program is ridiculously horrid at best. When it goes into full effect, there's going to be a lot of really surprised drivers and companies. There is still time to step away from the precipice and/or make some serious changes to it, but I don't see that happening.
Well, if the scale is open, you obviously have to stop and there is going to be a whole lot more of the "bring her around back, driver" going on than ever before, especially in the first 6 to 12 months of the program. So, we can change my example to just indicate that the driver got flagged for an inspection and the outcome is exactly the same.
In the end, the program will get rid of the unsafe drivers and the fly-by-night operations. But there will be a massive amount of collateral damage, as well, and that's the fear from both drivers and companies.
bentstrider 01-23-2010 08:55 AM
Unsafe Driving
Driver Fitness
Vehicle Maintenance
Cargo-related
Crash Indicator
So, say you're in my situation and got into an accident that's coming up on three years.
Do they retroactively factor in past accidents from that long ago, or are they going to be smart about it and just keep up with things that occur after the CSA 2010 thing goes into effect?
And also, doesn't anyone think these regs will be enforceable as an individual "state discretion"., a'la "truck-friendly state" being more lenient than a "non-truck friendly state"?
After living in California for so long, I could see the level of anti-trucker animosity going through the roof here, especially in the heavily scale-concentrated, Bay Area.
zipy46 01-24-2010 06:44 AM
CSA 2010 is not going to change the nature of trucking. :rofl:
If anything.... its going to put more owners and dispatchers in jail when one of the rigs
takes someones life.
bentstrider 01-24-2010 10:49 AM
Nothing wrong with that, especially with these fly-by-night operations I've dealt with since my debacle.
All run by Orange Co. CA preppies!!
Fredog 01-24-2010 02:55 PM
and it just might put dac or usis or whatever they call it this week out of business
Twilight Flyer 01-25-2010 12:25 AM
Not at all. This is just another hiring expense and given time, there will be fifty different companies offering the information. Besides, CSA 2010 deals solely with driving records, not with employment records.
Malaki86 01-25-2010 02:45 AM
Correction - they deal ONLY with inspections given by a DOT officer. They have nothing to do with driving records.
You can get a speeding ticket in Smallville, USA for doing 50mph over the limit, but unless a DOT officer comes out and inspects you, it doesn't go onto the CSA information.
chris1 01-25-2010 03:35 AM
If the city/county does what is required they will forward any CMV tickets to the DOT. Even parking tickets are supposed to be forwarded. If you are ever audited you will be suprised how many of those show up.
Twilight Flyer 01-25-2010 08:19 AM
Wanna bet?
Table 1. Unsafe Driving
177.800(d) Unnecessary dealy in HM Transportation - 1 point
392.2 Failure to obey traffic control device - 5 points
392.2 Following Too Closely - 5 points
392.2 Improper Lane Change - 5 points
392.2 Improper Passing - 5 points
...and so on and so forth through 16 different violation categories. Speeding is 7th on the list...5 points.
From what I have heard at this point is that MVR's are pulled into the point system, as well. The fact that the very first table is all about moving violations, tells me that they are doing it somehow. Even failure to use your seatbelt is on it...1 point.
They ain't messing around.
Malaki86 01-25-2010 01:45 PM
I was listening to the Land Line Now program the other night when they had FMCSA officials being interviewed. THEY stated that the CSA would only count with inspections done by DOT officers. You CAN get points against you for the things you stated IF the DOT officer is the one that stopped you for that reason, then proceeded to do a truck and/or driver inspection.
Jackrabbit379 01-26-2010 04:19 AM
Was that on Road Dog Trucking on Thursday night? I was talking to a Fed Ex driver, that I visit with when we cross trails every night. He told me about it, and I switched over. I caught the last 20 minutes or so, but it sounded confusing. :lol: :hellno: I had no idea what they were talking about, but it didn't sound good. :p
At first, I didn't think it would really apply to me, being local, but they were talking about points for this or that. :hellno: I better watch my P's and Q's. :lol:
Twilight Flyer 01-26-2010 04:54 AM
So the clarification that I got was that the inspecting officer can indeed refer to any violations in Table 1 and that they are laying the groundwork to possibly tie the CSA into a driver's MVR report. It will not tie in upon release date, but may do so at a later date.
So right now, if Barney Fife pulls you over for speeding outside Mayberry, those points will not show up on your CSA report because Barney does not have the authority to do the inspection.
A DOT officer, on the other hand, will have the authority to cite you for those moving violations and they will show up on the report.
Malaki86 01-26-2010 05:04 AM
Correct. For example, if you get stopped in Ohio by a DOT-authorized trooper for speeding or whatever, once they do an inspection on you, then they can apply the violations to the inspection as well as your MVR.
Fredog 01-26-2010 05:22 AM
how about if you just dont speed?
Malaki86 01-26-2010 05:29 AM
LOL - that works too. I must be doing something right - I haven't had a moving violation in over 20 years now.
Fredog 01-26-2010 06:54 AM
and you call yourself a truckdriver:):)
Jackrabbit379 01-26-2010 07:06 AM
I guess, the way it sounds... just don't get pulled over. Hmm. Ok. :thumbsup: :D
headborg 01-26-2010 06:41 PM
@ last two comments:
I can see it now... poor old outlaw trucker knows he's on his last violation-- and instead of pulling over and taking his "retirement" gracefully-- decides to give that trooper a run for his money. Going out in a blaze of glory- and make the TV programs-- worlds (fill in the blank) chases/ crashes video.
Fredog 01-27-2010 02:00 PM
well, thanks a lot for giving away my plan
Ronin 01-29-2010 08:44 AM
Al these shenanigans make me glad I got out of trucking when I did. It seems CSA is out to destroy the industry.
Twilight Flyer 01-29-2010 09:09 AM
Well, it's designed to make the industry and the motoring public safer and I think in the end, it will do what it's designed to do (after a whole lot of continued tweaking). My biggest concern is that the collateral damage it does to the driver base and many of them good drivers, is going to put huge pressure on the industry. I'll bet the Railroads are absolutely loving it, though. :roll:
Ronin 01-29-2010 05:32 PM
Hopefully the tweaking will involve remembering the concept of Due Process of law. Not providing drivers ways to appeal these summary decisions flies in the face of the core aspects of American law as demonstrated in both the Fifth Amendment (for the Federal Government) and the Fourteenth Amendment (for states)
No person shall be held to answer for a capital, or otherwise infamous crime, unless on a presentment or indictment of a Grand Jury, except in cases arising in the land or naval forces, or in the Militia, when in actual service in time of War or public danger; nor shall any person be subject for the same offense to be twice put in jeopardy of life or limb; nor shall be compelled in any criminal case to be a witness against himself, nor be deprived of life, liberty, or property, without due process of law; nor shall private property be taken for public use, without just compensation.
All persons born or naturalized in the United States, and subject to the jurisdiction thereof, are citizens of the United States and of the State wherein they reside. No State shall make or enforce any law which shall abridge the privileges or immunities of citizens of the United States; nor shall any State deprive any person of life, liberty, or property, without due process of law; nor deny to any person within its jurisdiction the equal protection of the laws.
And since they don't allow any appeal and rebuttal mechanisms for drivers, it's unconstitutional.
Ronin 01-29-2010 06:03 PM
IF they did make it retroactive (ex post facto) they'd be in violation of Article I Section 9 of the US Constitution which makes retroactive laws of this nature illegal, as well as the Fifth Amendment's provision against double jeopardy (since being added to history would be a punishment in addition to any standing fines/points already imposed for the infraction)
No bill of attainder or ex post facto Law shall be passed.
bentstrider 01-30-2010 09:29 AM
Well, aside from showing up on DAC and Driverfacts, none of this ever went on CA DMV or anything like that.
I figured no injuries or any real property damage outside of the truck itself, so a thin-line perhaps?
homer 01-31-2010 06:45 AM
Originally Posted by Ronin (Post 473746)
Al It seems CSA is out to destroy the industry.
i thought it was destroyed already.
no moving violation for 20 years then in 07 a slow mover hung me out in my car in the left lane after 20 miles of 38 mph.65 in a 55. (68 in 55 ) also had jury duty so i paid up.
this morning bootcamp is parked on a curve on steep hill and pops me for 5 over in my car(47 in 35)
i got home and turned on the scanner and bootcamp and his buddy are having a contest to see who writes the most fines and are assigning points depending on us highway or state route.he sed he was too busy too cuff me up to check the serial numbers on on my permitted concealed glock.
no violations in the slow semi-truck tho except the overload a heavy hauler always has on mvr
im gona have to add up the points soon
Windwalker 01-31-2010 07:52 AM
They already have the chases. Got to watch a truck circle the lot at a Pilot the other week. Taking corners on 9 wheels a couple of times around the lot, then out and gone... Only to come back about 5 minutes later with half a dozen squads behind him. When they cut off his exit, he bailed out and ran for the woods. Found out it was a 17 year-old kid out for a joy ride. I was sure he was going to roll it on every corner.
Or (was it Werner?) that was chased in Spokane a few years ago... Let his wife/girlfriend out, then went downtown? (or something like that.)
CSA-2010 may reduce them, but will not stop then.
