Originally Posted by Rat
Off Duty is Off Duty, Sleeper berth is Sleeper birth (not actually off duty).
An open container in a motor vehical (comercial or not) is an offense. Intoxicated in a vehical (comercial or not with actual physical control (having keys in hand,pocket or in the ignition) is an offense and can subject you to loss of driving privs similar to a DUI. Leave the beer at home for when you are logged in line 1 of your log book. If you are logged into any other line in your log book then you better not have an open beer or empty beer can or be intoxicated. It is simple as that and these are the laws. FMCSA laws can not be more lenient then these laws but they can be harder. |
BigDiesel said:
It is sad to see an individual, that finds it so important to have alcohol while out on the road.... and needs to pick apart the regulations. :roll: What our jr. matlock is failing to understand is the difference between the "spirit" of the law and the "letter" of the law....... The spirit of the law always carries more weight than the letter in the rule of law..... They have said: Alcohol is a LEGAL substance. We do not regulate ANY resting facility OTHER than the sleeper berth. Driving time is any time at the controls of a CMV IN OPERATION! On Duty time is all time OTHER than when a driver is Relieved of DUTY. We cannot guarantee that a driver will take advantage of the off duty time to GET the restorative sleep that he needs. NO company (unless they have provided written notification) can affect a "suspicion" test unless THEIR SUPERVISOR has witnessed a condition warranting such. (Not EVEN on the word of a consignee or shipper!) And MANY, MANY more regs and interpretations that allow for "exceptions" and "circumstances." But not ONCE did they clearly state that alcohol use was PROHIBITED by a CMV driver who is OFF DUTY! :roll: I can't help but WONDER WHY?? :roll: |
Rat said:
Off Duty is Off Duty, Sleeper berth is Sleeper birth (not actually off duty). An open container in a motor vehical (comercial or not) is an offense. Intoxicated in a vehical (comercial or not with actual physical control (having keys in hand,pocket or in the ignition) is an offense and can subject you to loss of driving privs similar to a DUI. Leave the beer at home for when you are logged in line 1 of your log book. If you are logged into any other line in your log book then you better not have an open beer or empty beer can or be intoxicated. |
Okay, so I'm on a 34 hour reset.... logged on LINE 1 of my logbook! 2,000 miles from home! NOW, what do you say? :roll:
According to the North Dakota State Highway Patrol.
Since the Sleeper berth is not seperated by a perm wall then you can get an actual physical control violation for being intoxicated in the sleeper of your truck. All you have to do is be in the truck (sleeper berth) with the keys readily available and you able to get behind the controls while being intoxicated and you are in violation. If your sleeper had a perm wall then you could be inside it intoxicated or with an open beer can. http://www.totaldui.com/pdf/dui_stat...rth_dakota.pdf Acording to this link the only time alcohol may be used in a vehical is by passengers in a bus or limo. Nuff said I believe. |
If he is nto staying at either of these and is in the berth then he had better be logged into line 4 unless he leaves the truck for a few hours. |
http://www.court.state.nd.us/court/opinions/900142.htm
Wow all kinds of stuff on the net about Actual physical conrol The above driver was convited for being passed out in the passenger side with his keys in his pocket. |
Yea, I messed up he should be logged into Line 2 rather then 4.
Wow all kinds of stuff on the net about Actual physical conrol The above driver was convited for being passed out in the passenger side with his keys in his pocket. (5) "Actual physical control" as used in this section, shall be defined as being in the driver's position of the motor vehicle with the motor running or with the motor vehicle moving. http://www3.state.id.us/cgi-bin/newi...id=180800004.K Or in Arizona where the statute is enforceable ONLY if the person blows a .15! |
| All times are GMT -12. The time now is 10:48 AM. |
