Working after 14 hrs
I came off OTR in Oct. '05 and went local when the new HOS rules started so I didn't read up on them too much. Last night a co-worker and me were talking about HOS and he said you can't WORK past the 14. I said you can keep working past the 14 as long as you don't drive, but you MUST take the required 10 hr break before driving again. So tell me, did the rule change in '05 ?
your right, you cannot drive past the 14th hour even if you have not used your 11 hours. You can work as long as you want and then you cannot drive until you get your 10 break.
In Texas, running intrastate, you can work/drive an extra 2 hours once, for every 70 hour restart.
Not sure how other states are. |
If you are a 100 mile radius driver and are interstate, you can use a 16 hour exemption once per duty tour. If you are an intrastate 100 mile radius driver, I believe the stricter of the state or federal laws apply. For example, New York allows driving up to the 15th hour after an 8 hours off duty as many times per duty tour as you can as long as you don't go over the 60/70 hour limit. So in New York the stricter of the two would be 15 hours once per duty tour after 10 hours off duty.
Too many exceptions to the 14 hour rule. Bosses keep getting them mixed up, and thinking that you can split it up with a 2 hour break. Correct me if I'm wrong, but if you are OTR, you have 14 hours to complete your day from which you start. So if you begin at 6:00 am, you got until 8:00pm to complete your 11 hours worth of driving. Is this correct?
Yes.... You can not drive after the 14th hour since coming on duty until you take your break.
That one exception is the 8 hour sleeper berth break. So, your boss is mistaken, a 2 hour break doesn't extend it. And your example is correct UNLESS you split log and/or take an 8 hour S/B break within that 14 hours. If you do, then you add the hours in the sleeper (8 or more, but less than 10) to the ending point of your day. One minor point that some miss is that, you CAN "stop the clock" with an 8 hour S/B break, and then shut down for a full 10 at the end of your "extended" day. |
And as far as the adverse driving conditions go, golfhobo, they don't extend the 14 hour clock. So there. :P |
The Rev spoke:
:oops: Ooops!!! :oops: You're absolutely correct, Sir!! I was reading 14 hour and thinking 11 hour!! My BAD!!! :lol: :lol: |
I had to agree to disagree with my dispatcher tonight about this.
i haul fuel, and i wanted to verify if i could log my post trip and fuel after the 14th hour as line 4. he said, no, it all had to be within 14 hours. I didn't say I disagreed, but I said, okay, i'll play it your way. if these people wouldn't be running me 560 miles with a single 100 gallon tank every day, i wouldn't have to ask these kinds of questions :/ Also, i seem to use my 16 hour exception on a regular basis here, and i was trying not to have to use it for a 15 minute fuel stop. It's not like I picked the equipment or the load or the route, but yet I feel like I'm the one who has to take the heat. |
I've always taken it to mean they want to simplify their compliance system by not tweaking the edges. When I worked for schneider they told me they don't "honor" the split sleeper berth rule, for example.
as far as i'm concerned, I put legality and safety over company policies, if I have to make a choice. I also like to know my options in case I ever really get stuck. These wisenheimers like to think they're clever by working against timestamps. For example, if i wait in line at a plant, but i haven't checked in, i can theoretically pencil out that wait time if i get in a jam later in the day. My theory is that, if an investigator really wanted to get creative, it probably wouldn't be hard to simply map the movement of my cell phone throughout the day. as far as I'm concerned, i -always- have a timestamp. |
It is a good idea to either get a copy of the federal regulations or check them out on line. Most carriers provide a copy to all new recruits. You can find a current copy at most truck stops. It will pay any driver to familiarize themselves with the regulations from the ones who wrote them. That way you know for sure. I remember when these rules kept changing, even the DOT people didn't fully understand them. You could get a different answer from two different officers in the same state. If there is a question and you have your rule book then you will know whether you are in the right or not.
from the fmcsa website
D. 14-HOUR DUTY PERIOD D-1. May a driver be on duty for more than 14 consecutive hours? Yes. A driver may remain on duty for more than 14 hours; however, the driver of a property-carrying CMV cannot drive after the 14th hour after coming on duty. Also, the additional on-duty time will be counted toward the 60/70-hour on-duty limit. |
