Pre-Trip VS Post Trip What's The Difference?
I got my package from the Alabama DOT, and have a few questions:
1. In the papers there was a post trip sheet? I have always done my Pre-Trips prior to starting my driving day, but never did a post-trip? I do check everything out on my truck/trailer every weekend very well, and annotate anything that is wrong. The letter states that this is one of the first forms that will be asked for in an audit or if you have an accident. Does anyone do a Pre-Trip and Post Trip every day, and if so how do you annotate it on your inspection sheet? I have the inspection sheet, but it does not say pre-trip or post trip on it? 2. The letter states I must be involved in a drug program for drug testing, and that I need to join a consortium that does this type testing. I thought that when I got my Health Card that this would be ok for my drug testing, but the letter clearly points out this has nothing to do with a drug program. How would you suggest that I find a company that does this, just start calling up Trucking Companies to try and find one that does this or what? |
Re: Pre-Trip VS Post Trip What's The Difference?
1. In the papers there was a post trip sheet? I have always done my Pre-Trips prior to starting my driving day, but never did a post-trip? I do check everything out on my truck/trailer every weekend very well, and annotate anything that is wrong. The letter states that this is one of the first forms that will be asked for in an audit or if you have an accident. Does anyone do a Pre-Trip and Post Trip every day, and if so how do you annotate it on your inspection sheet? I have the inspection sheet, but it does not say pre-trip or post trip on it? 2. The letter states I must be involved in a drug program for drug testing, and that I need to join a consortium that does this type testing. I thought that when I got my Health Card that this would be ok for my drug testing, but the letter clearly points out this has nothing to do with a drug program. How would you suggest that I find a company that does this, just start calling up Trucking Companies to try and find one that does this or what? §396.11 Driver vehicle inspection report(s). (a) Report required. Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each day's work on each vehicle operated and the report shall cover at least the following parts and accessories: see: http://www.fmcsa.dot.gov/rules-regul...11#49CFR396.11 (d) Exceptions. The rules in this section shall not apply to a private motor carrier of passengers (nonbusiness), a driveaway-towaway operation, or any motor carrier operating only one commercial motor vehicle. Pre Trip Section 396.13 requirement §396.13 Driver inspection. Before driving a motor vehicle, the driver shall: (a) Be satisfied that the motor vehicle is in safe operating condition; (b) Review the last driver vehicle inspection report; and (c) Sign the report, only if defects or deficiencies were noted by the driver who prepared the report, to acknowledge that the driver has reviewed it and that there is a certification that the required repairs have been performed. The signature requirement does not apply to listed defects on a towed unit which is no longer part of the vehicle combination. While reading the interpretations on section 396.13 I find something I would call a little odd Question 2: At the end of the day's work and upon completion of the required DVIR, what does the driver do with the copy of the previous DVIR carried on the power unit? Guidance: There is no requirement that the driver submit the copy of that previous DVIR to the motor carrier nor is there a retention requirement for the motor carrier. I wouldn't recommend NOT keeping it in the file however. As far as using a consortium for drug testing I would recommend OOIDA. kc0iv |
When I read over the letter ADOT sent me, it said that the pre-trip was prior to starting my driving, and the posttrip was to be done at the end of the day?
It also states that any type of maintenance done on the truck must be annotated on the post trip inspection sheet. I could not find in the letter if I am to do a inspection sheet on both my: Pre-Trip Inspection and Post-Trip Inspection. The letter states that the Pre-Trip should take 5 minutes, just a quick walk around to check: Tires, etc......, and the reason for the 5 minutes is that at the end of the previous day, it should have taken 30 minutes to 1 hour to do the post-trip, which is very detailed. I don't have to keep a log book due to the fact that I stay within 100 air mile radius so I don't have to log it, but just want to be sure to be legal. Any suggestions and advice would be greatly appreciated. |
Correct me if I'm wrong but I thought it was the other way around.
Per-trip 15 to 30 minutes to make sure it's safe to drive, post trips during stops and at the end of the day. |
Pre-Trip Inspection and Post-Trip Inspection. The letter states that the Pre-Trip should take 5 minutes, just a quick walk around to check: Tires, etc......, and the reason for the 5 minutes is that at the end of the previous day, it should have taken 30 minutes to 1 hour to do the post-trip, which is very detailed. I don't have to keep a log book due to the fact that I stay within 100 air mile radius so I don't have to log it, but just want to be sure to be legal. Any suggestions and advice would be greatly appreciated. Good luck doing a pre trip inspection in 5 minutes. :lol: Here's what a pre-trip consists of: §383.113 Required skills. (c) Air brake skills. Except as provided in §383.95, all applicants shall demonstrate the following skills with respect to inspection and operation of air brakes: (c)(1) Pre-trip inspection skills. Applicants shall demonstrate the skills necessary to conduct a pre-trip inspection which includes the ability to: (c)(1)(i) Locate and verbally identify air brake operating controls and monitoring devices; (c)(1)(ii) Determine the motor vehicle's brake system condition for proper adjustments and that air system connections between motor vehicles have been properly made and secured; (c)(1)(iii) Inspect the low pressure warning device(s) to ensure that they will activate in emergency situations; (c)(1)(iv) Ascertain, with the engine running, that the system maintains an adequate supply of compressed air; (c)(1)(v) Determine that required minimum air pressure build up time is within acceptable limits and that required alarms and emergency devices automatically deactivate at the proper pressure level; and (c)(1)(vi) Operationally check the brake system for proper performance. §392.7 Equipment, inspection and use. No commercial motor vehicle shall be driven unless the driver is satisfied that the following parts and accessories are in good working order, nor shall any driver fail to use or make use of such parts and accessories when and as needed: Service brakes, including trailer brake connections. Parking (hand) brake. Steering mechanism. Lighting devices and reflectors. Tires. Horn. Windshield wiper or wipers. Rear-vision mirror or mirrors. Coupling devices. §396.11 Driver vehicle inspection report(s). (a) Report required. Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each day's work on each vehicle operated and the report shall cover at least the following parts and accessories: Service brakes including trailer brake connections Parking (hand) brake Steering mechanism Lighting devices and reflectors Tires Horn Windshield wipers Rear vision mirrors Coupling devices Wheels and rims Emergency equipment |
Thanks Everyone this is what I thought also, that the Pre-Trip would be the longest one, and post trip shorter.
I have ordered the FMSCA Book, as could not find one at the Truck Stops where I travel. I am looking forward to getting this book and getting a better understanding of everything. Thank You Everyone for the great advice that you have gave me. I really appreciate it very much. Does anyone know where I could find the FMSCA on line, as well as a on line place that explains this book? |
Hey Rev, forgot a question for you, does this mean that I don't have to do paperwork on the Pre-Trip in the morning, but to wait until I get through in the evening and do the Post Trip and annotate it?
Sorry Rev, just got through reading your 1st reply to me and saw what I just asked you. I have to read things sometimes 3 or 4 times before I get it in my thinking.
Thanks Rev for the great information. |
Just a couple of notes on your questions. You should allow at least 15 minutes for your pre-trip on your log book. All you really need to do on the post trip is to note that it was done on the log at the end of the day. There are several companies who will help you with the drug consortium. OOIDA has a source that runs about $125/year, I believe. You can call them and ask. Most of them seem to run around $100/year per driver. There is a new log book which might help you keep your mileage, logs and inspections together. I found them at Pilot. Everything you need is on one sheet with perforations. The size is about letter size. I don't know exactly were you live in North Alabama, but I have also seen them at the Petro II at the Rainbow City exit, just South of Gadsden.
Thanks GMAN, I don't use a log book, but time sheet as I never go over 100 air mile radius. I found a website JJ Keller, and plan on ordering some inspection reports from them.
Thanks again. |
| All times are GMT -12. The time now is 10:20 AM. |
