Old 04-02-2007, 05:52 PM
Hat Rak's Avatar
Default Address on Medical Examiner's Certificate
I just realized after nearly a year of having moved away from Boston that my DOT Medical Card displays my old Boston address. Do I need to keep that address current? The certificate expires in a year.
I went through a DOT inspection once during my employment at Roehl and the inspector didn't seem to notice and/or care about the discrepancy between the addresses on my CDL which is current and that of my DOT medical card, which is not.
Thanks!
Old 04-02-2007, 06:45 PM
I wouldn't worry about it.
Old 04-02-2007, 07:08 PM
Hat Rak's Avatar
Thanks Rev. New employer, so I'm trying to make sure everything's kosher before I go in.
Old 04-02-2007, 07:31 PM
Mine doesn't show the correct address either. As long as it isn't expired, then you should be ok.
Old 05-26-2007, 07:12 PM
kilog55's Avatar
what about DL number? if the address is current but the DL is differant? cause i was planning on moving woul di have to get a new med card after i change my license over from state to state??
Just getting started
Old 05-27-2007, 03:24 AM
Skywalker's Avatar
I wouldn't worry about that either. Simply explain that you moved to a different state...and had to switch to the new state of residence's CDL. If the DOT gets hairy about it.... your employer can set them straight.
Forrest Gump was right....and some people literally strive to prove it.....everyday. Strive not to be one of "them".... And "lemmings" are a dime a dozen!
Remember: The "truth WILL set you free"! If it doesn't "set you free"....."it will trap you in the cesspool of your own design".
They lost my original "avatar"....oh well.
Old 05-27-2007, 03:56 AM
kilog55's Avatar
alright cause it expires end of Oct. '07 so either way i need a new on before then.
Old 05-28-2007, 03:07 PM
countryhorseman's Avatar
if he is going to a new employer, the new employer is I believe, actually required to have a DOT physical done at time of hire, regardless of the expiration date on his current med card.
So the address issue would be a no issue, since a new med card would be issued.
On the other hand, providing the current carriers records reflect his new/current address, then the address on the current med card need not reflect the correct address.
Texas still allows CDL drivers to use a PO Box on their license and other official records, regardless of physical address.
Louis
Old 05-29-2007, 01:38 AM
Dawn's Avatar
Louis
Some companies actually let you use the one from the past. Usually a smaller company will do this. Not sure if it is the right thing to do but some have done this.
The medical address means nothing! Only the drivers licences means anything and I am not sure on them laws so I won't even go there. I thought it was the state had to match the state you live in (this could be our company policy though). :?:
Old 05-29-2007, 03:37 AM
kilog55's Avatar
yeah i couldnt find any info on the fmcsr site so i emailed em about it. so hopefully they get back to me.
