-   -   Need Help with 1st Truck purchase ? (https://www.classadrivers.com/forum/owner-operators-forums/43292-need-help-1st-truck-purchase.html)
JB Express Transport 11-24-2012 02:08 PM
Originally Posted by GMAN (Post 519786)
I would not worry about the brand name. When I look for a truck, I look for value. I would stay away from the name specific engines, such as Volvo, Mercedes, etc., Parts can be expensive and you may need to go to a dealer for service, which will usually be more expensive than other options. I would also stay away from the super singles. When it comes down to it all trucks are basically the same. Most have the same engines and drive trains. The main difference is the interior. Decide what you want to do with the truck and then spec it for the work. It sometimes helps to make a list of what you want and then go from there.
Thats how I originally started out with the truck search...before I started acquiring all of the advice & oppinions. Volvo & Mercedes are definitely out for the same reason you stated. So that left me with I wanted a large sleeper & automatic. Everything else as far as engine,rears tires etc...I kind of looked at each vehicle's list of equipt.
I'm not looking at brand names...I dont know which one is better than the other. Just a collective of oppinions and BS is all I'm weighing at this point. I've drove or rode in all of'em...except the Mack ( Sorry Mackman) I keep coming back to the Pete.
Volvo's- Parts are a problem and being captive to a dealer for service
KW- Motors are unreliable
Pete- Cost a fortune to fix
Freightliner- All plastic and rattle apart...but good value
Mack-???
International-???
Thanks for the help GMAN....BTW...are you a Giants Fan...? Just a guess..?
JB Express Transport 11-24-2012 02:09 PM
Originally Posted by JB Express Transport (Post 519789)
I called on that one last week..I thought the mileage was to high for $45K...If I was going to go with KW...I found these two
http://www.truckpaper.com/listingsde...x?OHID=3777819
http://www.truckpaper.com/listingsde...x?OHID=3910267
I'm still stuck on a Pete...Thanks for the info though
Plus this one...Which i thought was good.. http://www.truckpaper.com/listingsde...x?OHID=3928133
JB Express Transport 11-24-2012 02:10 PM
JB Express Transport 11-24-2012 02:18 PM
Here's the Value truck
http://www.truckpaper.com/listingsde...x?OHID=3868673
$37500 out the door and over the curb
mitchno1 11-24-2012 02:29 PM
why are kw motors unreliable c,mon cummins the best
JB Express Transport 11-24-2012 02:39 PM
Just a collective of oppinions...Thats all. Cats or Cummins I thought were all good.
mitchno1 11-24-2012 03:06 PM
agree with rest of your comments tho ,not many petes here but yep dear to fix and yep frieghtshakers fall to bits here to
firebird_1252 11-24-2012 03:11 PM
most kw's are cat and cummins.
firebird_1252 11-24-2012 03:12 PM
and for what its worth.. unless you are going into CA.. i'd stay away from a 07+ newer trucks with all the emissions.
Bigmon 11-25-2012 01:55 AM
If you're looking at Petes have you checked out the ones that TMC are selling? I think the only color is black.
