Help With Info
Hey guys,
I'm trying to find out the unladen weight of my truck and for some reason I cant find it anywhere. Not in the manuals, not on the door jam, nowhere. It's a 04 Volvo VNL 630. If anyone happens to know off the top of their minds or knows how I can find out I would greatly appreciate it. |
put it over a weighbridge
Fill up with fuel and bobtail over to a cat scale and get a weight ticket.
Volvo doesn't publish the numbers like Kenworth and Peterbilt do on the door.
You have to scale it. Dealers should be able to give you an idea of what the truck would weigh. |
Originally Posted by Blacksheep
(Post 515614)
Originally Posted by allan5oh
(Post 515644)
The weight is with very little fuel. I forget the exact procedure they use. It's something like 40 gallons with a 200 lb guy in the truck.
The weight in the door is dry without ANY liquids, it is the sum of all the parts added together, factor in oil,coolant and fuel. Putting it on a scale tells the story
| All times are GMT -12. The time now is 01:02 AM. |
