outlaw68? |
06-01-2012 06:45 PM |
07 columbia cat c13acert help
need advice 3 weeks ago thought i had fuel line prob ,sucking air well check eng lite blinkin on <2 months> not all the time have cat manager on dash lite never on long enough to get code;ok figured it out cruse control toggle to blink code 92 intake actuator current high called cat said probly bad sensor not truck got worse pulled valve cover plug broke on #1 actuator coil replace 27,99 from cat runnin better smoke gettin worse dark smk when change gearonly inhigher gears or pullin hill.or jakefirst comes on. pulls great ,real bad white smk when you first start up then start moving !!!! mosquito killer oh and bad smell outside,&inside truck today noticed little puffs smoke commin from turbo cant see exactly where..please in input would be welcome,,,,ps boost 41,43 high end
