-   -   My MPG Dropped Significantly When I Changed To Fresh Oil!!! (https://www.classadrivers.com/forum/owner-operators-forums/42098-my-mpg-dropped-significantly-when-i-changed-fresh-oil.html)
Aufgeblassen 12-31-2011 01:26 AM
At 120,000 miles on the Delvac 1 oil of my 2006 Volvo 780 (w/ Volvo D12 engine) and about 650,000 total miles on the engine, oil analysis suggested I finally change the oil, so I did. I discovered my MPG on flat land w/ MT trailer dropped from around 9.0 MPG to around 8.0 MPG!!! :(:(:(
The good news, is that after a few thousand miles, my MPG is back up to where it should be. :smokin::smokin::smokin:
http://thesouthwindmotel.com/images/..._rv6d_bkmt.gif
firebird_1252 12-31-2011 08:41 AM
mine did the same.. i'm wondering if its the winter blend fuel?
Aufgeblassen 12-31-2011 01:47 PM
I buy all my fuel in FL, so we don't have winter blend.
YerDaddy 01-01-2012 02:46 AM
Have you had oil sample done? All I can think of is the fresh oil was thicker, as maybe the old stuff lost viscosity possibly due to fuel oil dilution. Hope not for your wallet's sake.
Aufgeblassen 01-01-2012 06:00 AM
The oil analysis said there was no fuel, water or glycol in the oil.
rank 01-02-2012 04:18 AM
I can't think of nay reason why that would happen. I've never noticed it happen to me with 20,000 - 30,000 intervals and dino oil.
Fredog 01-02-2012 10:53 AM
I'm still trying to digest the fact that a truck driver can spell
[h=2]Significantly[/h]
Mr. Ford95 01-02-2012 12:27 PM
Spell Check is a wonderful tool.
I'm thinking with YerDaddy, sounds like a heavier weight oil went back in than what was spec'ed. I know my personal vehicle got crappy mileage when I ran 10W until it got about 4,000 miles in on normal everyday driving to and from work. After that the mileage jumped up about 3 mpg. Of course on long distance trips 10W actually got better mileage than the 5W got.
Aufgeblassen 01-07-2012 10:58 AM
I am an engineer by degree. I launched rockets (Atlas, Titan) at Cape Canaveral Air Force Station until 05/05, when I became an O/O.
solo379 01-07-2012 03:07 PM
I tend to believe, oil has nothing to do with it. Or at least didn't played a major role. In any case it takes more than a small viscosity difference to loose a whole 1mpg! Probably combination of factors, but since it's back to normal, i wouldn't pay much attention to it....
