The "1/2 MPG Per 5 MPH Rule" Really Is True
I've always heard that you lose 1/2 MPG for every 5 MPH you increase your speed.
The other day with an MT trailer I determined my MPG @ my nominal travel speed of 60 MPH, and found it to be to be 8.9. I then increased my speed to 65 MPH, and sure enough, it dropped to 8.3 MPG. Unless you actually are in a hurry to get where you are going, you are foolish to drive more than 60. So what if it takes you 10.8 hours to get where you are going instead of 10? |
Originally Posted by Aufgeblassen
(Post 487703)
The other day with an MT trailer I determined my MPG @ my nominal travel speed of 60 MPH, and found it to be to be 8.9. I then increased my speed to 65 MPH, and sure enough, it dropped to 8.3 MPG. Unless you actually are in a hurry to get where you are going, you are foolish to drive more than 60. So what if it takes you 10.8 hours to get where you are going instead of 10? There is plenty better things I can spend $150 each week on than fuel and getting somewhere 30-45min earlier. Not to mention how much easier it is going 60mph and letting everyone pass you. Driving actually gets easier. |
That's probably how Columbus felt, when he discovered an America! To tell you the truth, it's a bit more complicated than that, but talking ABC, you are correct!
Originally Posted by Steel Horse Cowboy
(Post 487704)
I have found 8/10ths per 5 mph is more accurate for my setup. I have the testing #'s on this site somewhere. I found 5 mph made 3X as much difference as going in and out of the sweet spot.
Originally Posted by allan5oh
(Post 487736)
Both my 8.9 MPG & 8.3 MPG numbers were in the S/S. |
I agree, simply running the engine at lower rpms will get you better mpg even if you're below the sweet spot. The sweet spot is just a compromise between driver satisfaction and engine efficiency.
There are times where it makes sense to drive slower. when I used to leave out sun to go 600 miles I would drive 62 mph 7 55 in mi- oh, I calculated 2 runs a week would save me 800 a month. there are time where I run short hauls & can do 3 in a day. in those circumstances it would not make sense for me to save $10.00 on fuel, but lose a $300.00 load. one place I go to receives until 10 p.m. if I get an early start I can get 3 loads off, but I have to hustle & that means 68-72 m.p.h. though even on short runs if I am not pressed for time I will do 60-62-65
| All times are GMT -12. The time now is 12:04 AM. |
