Originally Posted by allan5oh
(Post 465655)
I'm pretty sure the published "sweet spot" of the engine is 1400-1500 rpms. Obviously that's BS.
Unless the RPMS are really low I doubt it. Electronic engines are pretty good. I think if you're light 100 rpms below the "sweet spot" is fine.
Next thing I'm expecting to see on here is someone saying that they cruise all day @900 RPM.:roll:
Originally Posted by Kranky
(Post 466236)
Have you got a digital tach?
. Tires=514 rpm (rotations per mile) x 2.64 (rear gears) = 1356.96 x 1.00 (tranny final ratio) = 1356.96 rpm @ 60 mph. 57 mph is 95% of 60 mph. 1356.96 x .95 = 1289.112 rpm. My tach actually shows about 1375.. |
(Post 466227)
Accelerating slower will not have anywhere near the effect that slowing down your cruise speed will.
Originally Posted by rgordon212
(Post 465981)
Thing is, with a light load, my fsc is paying for ALL of my fuel so it really makes no difference to me. |
With my Truck I tried it, and it did not matter what speed I went, I got the same bad fuel milage, 5.56. 55mph or 75mph. So I said why be a road hazard and go with the flow.
I simply found the very first post interesting b/c the poster did'nt take into account the other variables that others have already mentioned. Not every truck has a 13 speed or higher trans, everyones rears are different, and loads carried varies from 1 truck to the next. I know with my truck, a mid-roof volvo, w/ a straight 10 eaton, volvo d-13, 3.73 rears, and 48,880 load, my truck gets about 5.5 on level ground loaded. I never carry less that 47,000, and dead head back to the terminal when finished. My truck is goverened at 65. I average 5.8 over the length of any given run. On the other hand, another truck in the fleet with all the same specs, but having the ISX 600 gets better fuel economy than I do, and the empty combination weighs 1000lbs more than mine? I'm no math wizard, but I say to each his own, and for the record, with my setup, 65mph is at about 1550 rpms and still within the sweet spot zone. slower does improve fuel economy, but there is a point where one has to put good sense to use over fuel economy. If you get in an accident trying to save fuel going slow, than all the money you saved will just go to help pay your lawyers fees.
Originally Posted by coastie
(Post 467049)
it did not matter what speed I went, I got the same bad fuel milage...So I said why be a road hazard and go with the flow.
(Post 466227)
the speed the driver chooses will have the most effect on MPG.
| All times are GMT -12. The time now is 05:44 AM. |
