Is anyone using a Hydrogen Generator?
Hello Ya'll,
Just curious if anyone else is using a hydrogen generator on their truck. I have been experimenting one of my trucks for a while. I'm amazed (and excited) about the increase in fuel mileage that I'm getting. The truck is a 2003 Freightliner Columbia, with a 14L detroit. It has always been a pig on fuel. My quarterly IFTA MPG calculations have been between 4.9 and 5.3. The most recent Hydrogen generator that I have installed is by far the best. For 20k miles I have been getting between 6.25 and 6.95. I'm about to install my second unit soon. This time it will be on a Cummins. I hope to get the same results. -scott |
not sure I understand. you have a generator & it is used while driving your truck? I thought generators were what is used so you can turn off truck engine & run a/c heat e.t.c. without burning much fuel.
If you do a google search, there is tons of info on the technology. Let me know if you have any other questions. Thanks! scott |
I have read something on this. one sight was several glass jars hooked together. looked something you would see the professor create on Gilligan's island. lol. not sure how long glass jars would last on my bumpy riding truck. A while back.. a year or so a local man was installing some type of hydrogen on 4 wheelers & big trucks. I'm not going to knock it. just scared to try it.
It just a small (14" cube) that holds a few gallons of water. You have to wire it directly to the batteries. It pulls 20-25 amps. Using $2.65 a gal for fuel, a increase to 6mpg from 5mpg will save $11k a year based on 125k miles. -scott |
But I do have one question, Why are you only getting 6mpg? |
It doesn't increase you a full mpg. They don't produce enough hydrogen to do so. |
I use a flux capacitor. Mileage went through the roof.
As for the HHO deal, I've heard about it, and heard of folks getting good results, even though I still don't know how it's physically possible. |
The difference between 5 mpg and 6 mpg has less to do with the truck than it does the driver. |
Having run a highly boosted LS2 Corvette (14psi) I found the addition of a water/methanol spray into the intake air gave me fairly decent power gains - more due to the cooling effect on the intake air charge, then the octane value of the methanol. I really doubt this "Hydrogen Generator" (which separates O2 and H2 through electrolysis - remember Junior High science class?) produces enough hydrogen to be of either cooling OR fueling value. There has (to date) NEVER BEEN A METHOD that uses LESS ENERGY TO PRODUCE the hydrogen fuel, than the ENERGY VALUE of the FUEL THAT WAS PRODUCED. If only Morgan Freeman hadn't killed that scientist in that movie with Keanuu Reeves (Chain Reaction), maybe Neo could have found the secret to cheap energy. The rest of us just have to ante up $2.70 (average) at the pump, shift at the proper time, minimize downshifts, stay out of the pedal, keep out tires properly inflated and all that other happy crap that helps maximize our fuel mileage. Then again, if a $200 device "psyches" people into being better operators and it saves fuel - WTF is $200 anyway? Rick |
Give the man a cigar ! When you start seeing this stuff endorsed by the large mega carriers, then MAYBE you might be able to believe it, till then you have a better shot winning the powerball. |
Truckers Choose Hydrogen Power I figured I'd get the materials together, try it out on my car, and see what kind of results I get. For that matter, run "HYDROGEN POWERED TRUCKS" through GOOGLE and you get all sorts of results. Until then, I can't say one way or the other. But I can't see a company president spending that kind of money on a whim. Unless he's getting one hell of a "KICK-BACK". |
This truck has always been a pig on fuel, Can't figure out why. It does idle 10-14 hours a day when its on the road, so that's a large factor to the poor mileage. -scott |
I have seen a true increase in MPG on this truck. Have you installed a similar system and not had good results? Please explain. Thanks! -scott |
Hydrogen Generator | HHO Generator | MagDrive Fuel From H2o |
You can say what you want, I have actual data and your are stating your opinion. The truck that it's installed on is not the truck that I drive, so it's not likely that the driver has changed his driving habbits. I have discussed that with him, 90% of the time he uses the cruise control. The truck has a 10 speed autoshift, so the shift points are constant. -scott |
There's no such thing as a free lunch. . |
In a 1.8liter gasoline engine in a car, that kind of draw would be huge. However, in a truck, the load on the alternator wouldn't have enough affect to make a difference.
The solution is simple, put it on a dyno.
Say at 50% throttle the truck is putting 180 HP to the ground. Keep everything steady (rpms, throttle, etc) Now turn on the hydrogen generator. If the HP goes up, it works. If it stays the same or lowers, the hydrogen generator is actually hurting you. |
