"How do you figure? It's almost dead on to an OD13sp and 3.55's. People see the 2.93's and **** themselves. They fail to realize the fact the the tranny is direct drive..."
It is not a direct drive. I have a x-swift classic same specs they come with 9spd direct drives then when they are converted they become a 13sdp o/d not a big o/d it is a 0.86 final gear but still an OverDrive. All eaton 9 spd conversions turn it into o/d go to there website and look for your self. As for the specs they are ok while pulling my stepdeck around 65,000-74,000lbs I ran between 6.5 and 7.5 mpg depending on what part of the country I ran and no you don't spend a bunch of time trying to climb the hills you don't have to constantly keep spliting the gears either.I guess if you have not driven one you would not know.Now that I went back to pulling reffer @ 78,000-80,000 all over the country again im running 6.2mpg so far.I keep my speed down to 63 and that puts me @ 1325rpm with the 22.5 lopro rubber. I will prolly be going to 255/70-22.5 all position next go around and see what that does for the mpg. |
Like I said, it's almost dead on to a 13spOD(.73) and 3.55's.
An easy way to figure this out is to determine the overal ratio of both combinations of trans & rears by multiplying the highest ratio of the trans x the rear axle ratio. 13 speed; .73 x 3.55 rear ratio = 2.60. 9 speed converted to 13 speed; .86 x 2.93 rear ratio = 2.52. Converting the 9 to a 13 results in having a .86 overdrive when the stick is in 9th and the splitter button is in overdrive. When the splitter button is in direct, all the ratios are the same as if it was still a 9 speed, therefore you still have the same amount of reduction in lo gear that you always had. . |
The final in mine is actually .85, but he was close enough.
Revs per mile for that tire is 557! That's insane. That's near 1620 or so for 70mph. |
