any suggestions?
well, my truck seems to have settled on about 5.3 miles to a gallon, it doesnt matter if I go 55 or 65 or 75, it gets about the same. Any suggestons on what I might do? I know I need to get it put on a computer but other than that, what should I do?
it's a C-15 cat says 435 on the tag, but I dont know if it's been turned up. has 13 speed and 3.55 rears. |
You might want to put some injector cleaner in your tanks. If that doesn't help then I would take it to a shop and have them do a diagnostic on it. The cost should not be that great. It could be a number of things. It might be a bad injector. A friend of mine had one and it took a long time to find it. Most times you can tell if you have a bad injector, but if they are not firing properly they can be difficult to diagnose. I would take it to a CAT dealer and just have them put it on a computer if the injector cleaner doesn't work. I use transmission fluid in my fuel to clean my injectors. It is an inexpensive way to clean them. They make several different types of commercial injector cleaner. I know you don't want to spend the money, but you are burning a lot of fuel. If you could only increase your fuel mileage by as little as 1/2 mpg it will pay for the diagnostics in a very short time.
Originally Posted by GMAN
(Post 418719)
Yancy Cat in Atlanta Fre...Exit 51 on the Loop. Decent shop.
Dirty air filters could cause your engine to consume more fuel.
(Post 418764)
maybe spark plugs, points rotor and condensor would help. and new jets in the carb too. |
How many miles on it? Maybe it needs the "Rack" run??
It's a W9....so not going to get stellar mileage...but you should be able to get 6, maybe 6.3 mpg. |
(Post 418768)
I have a detroit engine that gets about 5.2mpg regardless of everything I do to it. I did overhead on injectors,change filters,put it on computer and still nothing. It has 1 million 100k miles on it. I try to go slow from 110mph to 60mph,get passed by mean old people and still fuel mileage same. WHY? Is it time for new truck,yes?
Originally Posted by Triple Digit Bob
(Post 418778)
I thought you were going to tell me to try farting in the fuel tanks. |
Stowers Caterpillar on hwy 153 in Chattanooga has always been fair with me.
I just thought of something, Fredog. When you check your fuel mileage to you rely on the computer or odometer?
Originally Posted by Fredog
(Post 418716)
(Post 418849)
Originally Posted by Heavy Duty
(Post 418873)
Check the charge air cooler, if mileage doesn't improve at slower speeds it is probably leaking. Higher RPM's help it overcome the leakage. Cheap to check, I would do it first.
I try that with my truck. Still no work. |
(Post 418873)
Originally Posted by Kranky
(Post 418889)
I'll second that.
| All times are GMT -12. The time now is 08:34 PM. |
