-   -   Fuel economy question (https://www.classadrivers.com/forum/owner-operators-forums/35593-fuel-economy-question.html)
flatbedin 09-17-2008 11:19 AM
Not going to lie, I come from a long line of flatbeders, and that's all I know. I have always had a large car with a big cat.
With today's fuel prices, and market. I want to set up a truck that will be "multi-talented" if you will. Pull a skateboard when the money's there, and a refer or van when it's not.
With real world figures, what truck would you buy (motor, ratio, ect) and why?
I have tried to research fuel milage on the detriot, isx, and d-16, but don't have any real numbers to play with.
I can say that my Cat will get 6.5, but only if I set the cruise at 58 and don't stop for 11 hours..
Thanks
GMAN 09-17-2008 11:39 AM
I have an International 9400 with a CAT that averages about 6.29 and a T600 with the same engine that has been averaging around 6.91 mpg. Both have the same engines. The International has a 10 speed spicer with 354's. The KW has a super 10, but I don't recall the gear ratio. Both trucks are primarily driven around 65-70 mph.
charged 09-17-2008 11:51 AM
My dads 2003 international 9400i eagle with a c15 has been getting 6.1 mpg. It has an eaton ten speed auto and 3.36:1 gears. Steers are goodyear G395LHS, drives are recaps except for two new yokohama TYS77. Size are 295/75/22.5. He pulls an aluminum 48' flatbed. No fairings single turbo.
flatbedin 09-17-2008 12:07 PM
Gman, do your cat's have twin turbo's or non twin?
Also I know that aerodynamics doesn't play as big of a role when flatbeding, as it does with a van and refer. Do you have full fairings on your international?
I've been looking at the Volvo 630, I personally think that they are cheap made, and hold no re-sale value. But it's money in the bank vs money out the stacks at this point. If I add full wheel fairings, with a removable top, that would give me the ability to put the top on when needed, and take off when pulling a skateboard.
Does anyone have a ISX that can tell me what the maintenance looks like? The few guys that I have spoken with, say that the ISX is nickle and diming them to death.
GMAN 09-17-2008 01:01 PM
Flatbedin, I have a single turbo on both trucks. I also have full fairings.
no_worries 09-17-2008 01:48 PM
Are you looking at a new truck, a used truck with EGR, or a pre-EGR truck? Big difference in those engines. Might as well be apples to oranges if you're not comparing the same vintage.
rank 09-17-2008 03:44 PM
1998 KW T800
M11 Cummins/370 - 410 hp/13 spd/4.33 rear gear/22" rims/Lo pro tires/high rise bunk. I drive it 60 mph pulling decks around the northeast and I get 6.75 - 7 mpg in the summer. I gross 80,000 southbound and I pretty light heading north.
2001 KW T2000
C15/475 CAT/13 spd/3.73 rear/22" rims/Lo pro rubber/high rise bunk. The driver drives it 70 and he gets ~5 mpg.
2008 KW T660:
485 ISX/13 spd/goverened at 70/high rise bunk. Pretty much the same mpg and driving habits as the T2000.
[/u]
GMAN 09-17-2008 11:26 PM
The driver will have as much or more to do with fuel mileage than gearing or anything else. While gearing and spec's are important, it is still the driver that makes the difference.
Copperhead 09-18-2008 06:55 AM
Yep, you can have the best specs in the world but a lousy driver will still get lousy fuel mileage. A good driver can often compensate for less than stellar specs, not always, but most times. A good driver with excellent specs can pull some real eye opening mpg's.
no_worries 09-18-2008 09:38 AM
It's his own truck, so the driver is a constant. Therefore, the specs make all the difference.
