-   -   little help (https://www.classadrivers.com/forum/owner-operators-forums/32289-little-help.html)
ender 02-09-2008 07:05 AM
little help
I know I should ask oodia this question.
But I just singedup And I probably wont get an answer untill membership comes trough.
Can anyone tellme if I need a permit to enter KY ,or TX ,other than my DOT and MC numbers?
I read about people tryng to get TX, dot or KY permits.
I'm from CO, and cant find anything worth houling, so I need to head east for a couple of weeks so I can make a little money.
Any help would be appreciated.
9200IH 02-09-2008 08:30 AM
Here is a link for the KY number. $75.00 ticket I think if you don't have it
http://www.kyu-number.com/order/order.htm
I don't know how to make it clickable but the above address will get you there.
I don't think there is another permit for TX.
There is for NM too
GMAN 02-09-2008 11:28 AM
Kentucky requires you have a KYU number. Texas only requires a TX DOT number if you haul intrastate or within the state. That means that you must pick up and deliver the same load within the state of Texas. There are a few other states who require a permit or state authority if you pick up and deliver within the same state. New Mexico also requires a permit which costs $2/year per truck. New York has a HUT permit. I don't remember the cost. Oregon requires that you either get a permit for each trip or pay a $2,000 cash bond to run in their state. The cost is $0.13/mile plus $9 for each trip permit. The trip permit is good for 10 days. I believe those are the only ones who require additional permits. As long as you have the states on your cab card you should be good to go.
Jackrabbit379 02-09-2008 11:57 AM
GMAN, for you not being from Texas, you sure know a lot about TXDOT. :shock: :) :lol:
Dispatch_This 02-09-2008 01:52 PM
Here are the states that require more than IRP and IFTA as far as permits go:
N.Y. Must pay HUT based on mileage
N.J. Must pay $500 Annual Corp. tax unless Sole proprietor
KY. Separate mileage tax, state DOT# required on truck
AR. Prop. Tax based on assesed value of Equip. and mileage run in state
KS. Same as AR.
N.M. Weight-mileage tax- Cab Card no longer required, can buy annual permit at N.M. website
CO. Declare # of power units registered, Last 8 of VIN# required on side of truck.
OR. Does not collect fuel tax at pump- Must buy trip permit before entering state, or post bond for annual permit.
I'm sure that others will pipe in if they find something wrong with this...
