OK, I'll throw in a different angle:
What if all the old timers educated the newbies on cheap freight, what it costs to actually run a truck, etc.. And told them how crappy and cheap some of these companies are(england, hunt, etc..) If they worked for better paying companies, both company driver and o/o, what do you think would happen to rates? |
Operating costs vary depending on how much fuel an individual truck consumes. Anywhere from 1.00 to 1.10pm. 1.15-1.20pm is not uncommon for a reefer. So a load paying 1.20pm would be nearly break-even.In other words,nearly zero profit. Nursery stock DOES pay well and runs pretty strong in the northwest during March thru May. Most of them have at least 5 drops,but they all come off very fast. I was able to get all 5 off the same day when I used to haul it. The broker that has those loads is Pacwest. Pepe,you may be able to use a vented van to haul those. The best way to get higher revenue living in Ca. would be to get a load going straight up I-5 to the northwest in March and reload with nursery stock going to the midwest. You should be able to average 1.80-85 for these turns depending on how much you deadhead. Pepe,it is all yours since that area isn't my cup of tea. :lol: I usually move the produce out of Ca. during the season with my reefer. |
Merrick, I subscribed to Real Time for about a month or two. Everything I saw was very cheap. I don't recall seeing anything for $2/mile or more. Most everything I saw for a flat bed was around $1.30. I cancelled my subscription.
I'm new to this site, but not to others. This thread caught my eye and I wanted to post my experience as an o/o. In the interest of time I've provided a link to my experiences.
http://www.layover.com/forums/layove...-oo-80870.html |
[quote="GMAN"]
Carrying a forklift on the back of a trailer is a lot of extra weight. Unless it is something you need on a regular basis, I would not carry one. There are some brick haulers who also carry them. They mostly have then because they deliver to construction sites and that is the only way to unload them unless you want to do it one brick or block at a time. I don't know of any owner operators who haul them around. It is mostly company trucks and that is all that they haul.
For flats I would consider a side kit and perhaps extra tarps, especially a couple of smaller tarps, such as 16 x 20 or 16 x 16 if you plan on doing much LTL freight. Other than that I would carry hand ratchet straps, 3" or 4" and 2". I have kept as many as 10 of each on my truck. It is only extra weight unless you need them. I would not rush out and buy a lot of extra tarps and straps. The hand ratchet straps do come in handy and can be used a little easier than the larger trailer straps in some instances. You can manage without going out and buying a lot of extra tarps, etc., I would wait to see what type of freight I was hauling before going out and spending a lot of money on things you are not sure you will need. You can use the larger tarps, but the smaller ones are easier to use if you have several smaller LTL's that need to be protected. |
GMAN, with a side kit, does it make securing a load more difficult or time consuming? What do the straps or chains attach to? I can never tell when I see one on the road.
RostyC...you beat me to the keyboards as I had almost the same question....
GMAN: What benefit does a side kit add over plain ol tarps. Also....what would you consider to be the better of the following two options and why...(1) a side kit or (2) a roll back tarping system like Roll-Tite? |
