knucklebreaker
what is a knuckle breaker trans and why is it called that?
Re: knucklebreaker
Do you win a high-paying load out of Tx if you answer it right? :lol: |
Re: knucklebreaker
its a 15 speed, now someone else tell why its called a knuckle breaker.
holy cow. nobody?
A 15 has a U shift patten, meaning the "Big" hole is a forward movement of the stick. If you wrap your hand around the front of the shift handle, you tend to punch the dashboard, informing you the shift is complete. :lol:
All 15's are knuckle breakers then? you're kidding me. I haven't hit my knuckles once.
not all of them, they were big in cabovers, especially KW cabovers.
Depends on the model trans. RTO xxxx15 transmissions have the "U" shift pattern.
ok. the 15 we have is an RTLO....basically a 10 with 5 gears of deep reduction. It's in an '85 T600. never had a K100......
thanks |
OPPS
If its a double overdrive its a "knuckle breaker", not ALL 15 speeds are double overs, some had only 1 overdrive.
Also a double over would be an RTOOxxx15 18 speeds are double overs, but have something that turns the last shift around so its in the "normal" position (rearwards and back) There were 13 double overs also, but were/still kinda rare. |
Re: knucklebreaker
Nevermind. I already found one. :lol: If it wasn't for LOADIT's invisible PM I would be lost on where to look. :lol: |
Re: knucklebreaker
