mine is a company truck with teh stupid air dam on top, so no flat roof real estate for solar panels.
Originally Posted by Doghouse
To have a panel that maintains your batteries does not have to be very big,..maybe like this one
http://www.talcoelectronics.com/p-68...y-charger.aspx It comes with its own charge controller, and will keep your truck batteries fresh. but for recharging batteries that crank slowly from use while truck engine was not running,......you'll need a set of these bad boys [img]http://i155.photobucket.com/albums/s...olarpanels.jpg These will bring my batteries from 10.5 volts to 12.8 in about 45 minutes. There are 390 watts of power being generated, and they run through a hi voltage charge controller, the spark these throw is clean and blue, and they actually have too muck electrical flow for a 50amp fuse, the fuse get too hot to touch.[/img] |
I'm guessing DH got the panels from here:
http://www.talcoelectronics.com/c-11...ar-panels.aspx $2940.00 on sale! |
A place called RV solar, do a search and ask for Doug, he was very good during the whole project.
http://www.rvsolarelectric.com/ Try this |
| All times are GMT -12. The time now is 04:16 AM. |
