-   -   MPG VS. SPEED (https://www.classadrivers.com/forum/owner-operators-forums/27571-mpg-vs-speed.html)
PhuzzyGnu 06-08-2007 06:12 PM
I can't find it now, but I once had a copy of a study done by an economics professor and his class at a major university that studied speed vs. economy and its effect on owner-operators.
Their conclusion? The speed that an owner operator should go to get maximum results (cost/time/profit):
As fast as the truck would go.
-p.
allan5oh 06-08-2007 07:24 PM
And that study was probably done when fuel was $1 a gallon.
$3 a gallon fuel changes everything.
solo379 06-09-2007 04:06 AM
Not really! It just changes the final numbers!
And that study, was probably done on a paper, w/o actually considering reality. Which is quite different from the theories!
Anyhow, whatever makes you happy, I've done my own "studies", and come to my own conclusions! :wink:
WingmanIII 06-09-2007 08:29 AM
MPG VS. ECONOMY
You know I didnt even figure in the savings in maintenance costs. I believe driving slower reduces wear and tear on the engine also, no matter what you have under the hood.
What do ya'll think about that turbo 3000 fuel atomizer, and centrimatics? any fuel economy savings noticed? thanks
BanditsCousin 06-09-2007 08:36 AM
Driving slower doesn't necessarily save wear on the engine. my reasoning is 60mph in my truck (12th gear) will do 65-ish in 13th gear, and at the same rpm. However, you'd be pushing a little more wind.
Going slow does sav fuel, considerably. 75mph across the west vs my last trip going 71mph yielded .5mpg+ increase in economy.
If you go slower, you can log it at the speed limit, but thats about as far as I'll go on that topic :wink:
allan5oh 06-09-2007 10:39 AM
The less horsepower an engine needs to make the longer it lasts. It doesn't have to do with rpms.
Ian Williams 06-09-2007 01:06 PM
Re: MPG VS. ECONOMY
It depends.
For some components life is measured in hrs while for others it is in miles.
At my company our P&D tractors that don't leave town wear out steer tires every 60k miles with all the turning and backing they do.
Longsnowsm 06-10-2007 11:41 AM
I am very happy to see the peaked interest in fuel economy. I am a fuel economy junkie of sorts so I actually started learning how to wring fuel mileage out of my TDI VW just for the fun of it. So it does my heart good to see that fuel economy has become a thing of great interest.
There are several great articles out there on how to get the most MPG out of your truck. Cummins has this interesting article called "Dr Diesel's Secrets to Great MPG:
http://www.everytime.cummins.com/eve...Whitepaper.pdf
There is also an interesting diagram on the Paccar site showing some of the points of interest and relative percentages saved:
http://www.kenworth.com/brochures/FuelEfficiency.pdf
I always find it interesting how different drivers driving essentially the same vehicle can get huge differences in economy. The Cummins article points that 30% difference can be achieved in just the way you drive. I know I added a car computer to my car so that I could learn to drive the torque of my diesel and not the rpm. The savings is substantial once you learn the techniques, and of course slow down.
The other factors aside from your driving technique that can help is synthetic fluids, and tire pressures, and tire choice(all position tires everywhere). The aero is pretty much cooked into whatever truck you own. You can move the trailer forward. Kenworth says 36" separation for best results.
I find it funny that the engine manufacturers won't talk about fuel consumpution figures on the bench(take the driver and the other variables out of the equation). It is too bad that there are no EPA MPG numbers like you see for a car on big rigs. I would also like to see the CD(aero drag) numbers for a vehicle. Freightliner is talking about the Cascadia as being the slickest truck out there, but to look at it and thinking about how air moves and works I am not buying it. I would love to see some heads up aero comparisons with the latest aero trucks to really see what we are talking about as far as aero advantages. Fuel prices only go up from here and year over year I only see it continuing to trend upwards. It is time that more scrutiny is paid to these details. If you guys know of any aero comparisions on the big rigs I would love to see them.
Also I would love to see a formal rolling resistance standard developed for tires published. They have just danced around the issue in consumer car/truck tires and a limited amount of data is available. I haven't seen anything for truck tires. Has anyone seen anything like this for truck tires?
Longsnowsm
allan5oh 06-10-2007 04:07 PM
No kidding! I said the same thing about a year ago. We need these #'s to make a good business decision. Right now it's mostly luck. Which engine will be the best next year, nobody knows!
What you could do to eliminate all variables is put an engine on a dyno, and have it make 200 hp. Do about 10-15 different engines this way. The engine that makes 200 hp for an hour and consumes the least amount of fuel is your winner. 200 hp is 200 hp, it doesn't matter if its a 16 litre cat or a 10 litre cummins.
PackRatTDI 06-11-2007 02:15 AM
Looks aren't everything when it comes to aerodynamics. SAAB used to have very quirky designs that were quite aerodynamic but didn't really look it. Since SAAB started as an aircraft manufacturer, they knew a thing or two about aerodynamics.
