Running in cold weather......
Im gonna be running from chicago/milwaukee to seattle, portland, west coast alot and am wondering what precautions to take in cold weather, and when does is start to snow in the west you know thru the mountains on I80 and running through idaho and montana,, now ive ran south most my driving career and comparing the south to the west and NW, when it comes to cold weather there is none right? i know about howe's to prevent your fuel from gelling or what not but how exactly would i use it and what other precautions can i use??, and i have a tripac on my truck so i wouldnt idle, but i understand you have to idle at some point when it gets below what tepmerature??? I tend to ramble on, thanks for your help in advance!! :lol:
Running across I-80 through Wyoming you better be prepared for snow in Oct. I ran across Wyoming last week and had some light snow,nothing serious , but just showing everybody that winter is only a month away.Montana can be just as bad in Sept. and Oct. with a early snow.The worst is when it is warm during the day and snows and blows at night and makes the roads really slick.
Re: Running in cold weather......
If you're buying your fuel from reputable places in those northern areas, you shouldn't have a problem. Fuel is treated to handle local temps. Having said that, if the temp drops below 10 I usually add Lucas.
The worst part about the cold is how hard it is on your engine. Batteries don't hold as much of a charge which stresses your starter and oil becomes thick which causes accelerated wear-and-tear. If your Tripack heats the block then that's great. I usually idle, again, when the temp drops below 10. |
forget about the truck you need to worry about yourself first and foremost, heavy clothing, blankets and non perishable food should always be in your truck, theres a very real possibility of you being stuck on the road in the middle of nowhere for days straight.
i`ve got complete hose and belt replacement sets in my truck as well a roll of hose tape so I can seal a leak if its bitter cold out and dont have the time to replace a hose in the weather, in addition I have fuel filters an oil filter, engine oil and gear oil, an alternator, starter, turbo, a basic tool set (sockets wrenchs screwdrivers for every bolt on the truck) as well as an air hose and 1/2 impact gun for tire changes, I also keep a spare tire and spoons for changing a tire. all together minus the tire all those tools and parts weigh around 350 pounds, not a big deal weight wise when I can save myself thousands on a road repair or even better get myself out of dangerous weather. i`ve also got kindling and butane torch for starting a fire under my tanks when i`m in extreme weather, I dont care who you buy your fuel from sooner or later its cold enough to gel it. now I run out west exclusively with the occasional canada/alaska trip and I can repair anything on my truck so you may not want or need or even be able to use everything I carry but its all worth it to me. |
Uh...... Isn't today the " unofficial " start of summer ???? Why worry about winter weather now.... :roll: :roll: :roll:
i`ve got complete hose and belt replacement sets in my truck as well a roll of hose tape so I can seal a leak if its bitter cold out and dont have the time to replace a hose in the weather, in addition I have fuel filters an oil filter, engine oil and gear oil, an alternator, starter, turbo, a basic tool set (sockets wrenchs screwdrivers for every bolt on the truck) as well as an air hose and 1/2 impact gun for tire changes, I also keep a spare tire and spoons for changing a tire. all together minus the tire all those tools and parts weigh around 350 pounds, not a big deal weight wise when I can save myself thousands on a road repair or even better get myself out of dangerous weather. i`ve also got kindling and butane torch for starting a fire under my tanks when i`m in extreme weather, I dont care who you buy your fuel from sooner or later its cold enough to gel it. now I run out west exclusively with the occasional canada/alaska trip and I can repair anything on my truck so you may not want or need or even be able to use everything I carry but its all worth it to me. Are you getting all this, Marcel? :lol: Carry a bag of salt and practice with your chains ahead of time. Driving in blizzards, white outs and on icy mountains is more fun than any single individual ought to be allowed. 8) |
another intelligent post, your a real winner :roll: i`ve seen 30 degrees at night throughout the year. |
i`ve got complete hose and belt replacement sets in my truck as well a roll of hose tape so I can seal a leak if its bitter cold out and dont have the time to replace a hose in the weather, in addition I have fuel filters an oil filter, engine oil and gear oil, an alternator, starter, turbo, a basic tool set (sockets wrenchs screwdrivers for every bolt on the truck) as well as an air hose and 1/2 impact gun for tire changes, I also keep a spare tire and spoons for changing a tire. all together minus the tire all those tools and parts weigh around 350 pounds, not a big deal weight wise when I can save myself thousands on a road repair or even better get myself out of dangerous weather. i`ve also got kindling and butane torch for starting a fire under my tanks when i`m in extreme weather, I dont care who you buy your fuel from sooner or later its cold enough to gel it. now I run out west exclusively with the occasional canada/alaska trip and I can repair anything on my truck so you may not want or need or even be able to use everything I carry but its all worth it to me. Are you getting all this, Marcel? :lol: Carry a bag of salt and practice with your chains ahead of time. Driving in blizzards, white outs and on icy mountains is more fun than any single individual ought to be allowed. 8) :lol: :lol: :lol: |
The kindling has dual use for sending smoke signals. Use morse code and stay away from Indian languages because not many people know them anymore. You're really sure about this? :D
Seriously, I don't want to drag you down. That winter driving gets tough though, doesn't it? You make the same amount of pay driving on dry pavement on a sunny day as you do in the pray as you go, white knuckle moments. You sometimes drive past the jackknives and deal with the unrelenting, 'should I or shouldn't I?' Try to get to the end of the storm or park it and get comfortable? I guess you know all this. Myself, I'm reluctant to have to do a lot of winter driving anymore. Obviously, everybody doesn't have that choice. I've done it, can do it, may do it again. But, I think we all have to ask ourselves, is it really worth the risk? A bad day on the ice and snow could prevent many future summers of relatively carefree, pleasant driving. So, enough of my spiel. I guess there is more room for anyone who has something to say about just how to do the winter driving. I doubt I'm completely done, myself. |
actually theres money to be made or lost in bad weather if you know what to look for, i`ve taken expedited loads to northern alberta/bc and alaska where I stood to lose thousands if I was late.
when did I claim that?
37 posts from ya and nothing but garbage sunshine. |
no
are you a jackass? wait dont answer that, anybody whose read your posts already knows. |
no
are you a jackass? wait dont answer that, anybody whose read your posts already knows. Pot... Kettle... Black... BTW... learn how to write... :roll: :roll: :roll: |
I KNOW YOU ARE BUT WHAT AM I!?!?
http://www.scorcher.org/screed/html/...wee-bottom.jpg |
LOL :lol: :lol: I like that one CAM!!! :lol:
Ol' Pee Wee :lol:
SHHHH!!!! Im listening to reason!!!! :lol:
| All times are GMT -12. The time now is 08:34 PM. |
