Volt gage reading too low
Has anyone had a problem with a 200 Volvo 770 with a N14 showing lower volt readings on the dash reader? I had this checked and when to tester hooked to the batteries it shows 12.4 volts with the truck not running but key is on. The dash readers says 11.7 volts and this kicks the Battery protection system on and shuts everything down in the accessory side of things so that truck will start. Any ideas on what causes this to be different readings? The local Volvo dealer didnt have a clue.....go figure. Thanks!!
You could have a weak battery. You may want to have each battery checked. If you go to Autozone or some of the parts stores, they will check them for you for free. To check the individual batteries you will need to disconnect them from one another. That is where I would start. You may also want to check to see if any of the cables are loose.
Thanks Mr GMAN....That was done last night. It has 4 new batteries that are a week old. This is why this problem came to my attention. Cables are all good and all batteries checked out ok. Charging system was check at idle is was at 13.9 volts. Truck read 13.2 volts.
Is it possible you have a deadshort happening some where in the wiring?
Check exposed wires..especially those that were installed afer truck was built. my .002 |
| All times are GMT -12. The time now is 01:47 AM. |
