-   -   how big is a STEEL COIL?????????????/ (https://www.classadrivers.com/forum/owner-operators-forums/23117-how-big-steel-coil.html)
rank 12-16-2006 09:25 AM
diameter and width???????????????
knightwolf71477 12-16-2006 09:34 AM
The size of a coil varies, I have seen them small and large. But all the coils should be able to fit on a trailer and most coils can fit in a covered wagon.
rank 12-16-2006 09:59 AM
I'm going to make some coil racks...need to know the diameters don't I?
Justruckin 12-16-2006 11:17 AM
Just go to a good trailer shop, I pay $12 a piece for them. And those are the heavy ones. I haul 46,000 lb coils with them all of the time and have never had one break.
And I get the 6' beveled oak for around 6 bucks a piece, with no cracks.
rank 12-16-2006 11:55 AM
[quote="Justruckin"]
Just go to a good trailer shop, I pay $12 a piece for them. And those are the heavy ones. I haul 46,000 lb coils with them all of the time and have never had one break..
4 trailers x 4 coil racks per trailer (possibly more if I need different sizes) @ $12 is about $200. I could build my own in anout and hour for a 1/4 of that cost.
Now, how big are those 46,000 lb coils if you don't mind me askin'? :wink:
I've seen two different sizes for sale online. I've also seen a coil rack that's designed so it suits two different size coils....so I know different sized coil racks are required.
Justruckin 12-16-2006 01:19 PM
Well!!
What size coil do you intend on hauling?
I have only seen three sizes, the ones on skids, the little ones and the big ones!
Which one do you intend to haul?
I find that the coil racks that I have handle all sizes. If you have a truck stop nearby, take a tape in and measure those things.
Now, if you are talking some ridiculous size and weight, you might want to upgrade to 6x6 beams and some huge coil racks. I have seen them on some company trucks that haul some huge stuff. But this is the norm with a contract steel hauler that does that, and only that. I normally do coils as a way home, they pay ok, and get the job done, mainly get me home.
:wink:
Justruckin 12-16-2006 01:22 PM
Hell, I'll get off my lazy arse and measure one for you. Just give me a minute. :evil:
Justruckin 12-16-2006 01:31 PM
All right,
3/8 inch thick steel
Across bottom, 37 and 5/8 inches
Where the coil sits, 26 and 1/2 inches
And I measured twice and wrote it down in the process.
Hope that helps! :wink:
Oh, you do know what a coil rack looks like, don't you? :shock:
special k 12-16-2006 02:09 PM
It's not really the weight but the width of the coil that can throw you for a loop. If you have a 20,000 lb coil thats 70" wide the coil is so small in diameter that somtimes it'll hit the floor first instead of the blocks. I just double block it on one side to narrow it up and the coil doesn't hit the floor. There are coil racks that hold the wood at the proper angle and they have two position on either side for small or big diameter coils. The other nice thing about these is that you don't neeed to carry bevelled wood just good 4X4's
Justruckin 12-16-2006 02:12 PM
Yep, that's right on the little ones. Poor orphaned coils... :cry:
rank 12-16-2006 02:50 PM
thanks justruckin. 3/8"!
EXACTLY! That's why I was thinking there had to be different sized racks.
Ahhh, I never thought of that. That's what I've been missing. Thanks.
Yeah, that's the type that I planning to build. I was thinking about a piece of flat bar with two pieces of steel angle welded onto the flat bar so that the angles trap the 4x4's at a 45 degree angle. Once I know the coil's diameter, it's just a matter of positioning the angles to keep the coil off the deck.
...and yes I do know what a coil rack looks like.:)
rank 12-16-2006 03:01 PM
Double post........sorry
Rawlco 12-16-2006 03:52 PM
The ones that TMC uses are a piece of flat bar with six peices of angle welded to it. The two outermost pairs are 2 inch angle, with another inside that of about 1.25 inch angle. This allows the 4x4's to be placed in several different notches for various coils. I would buy or borrow one to copy to make sure you have all the right measurements. If you have a standard rack the loading crew will know which notch you want the 4x4 set into to make the coil fit properly.
GMAN 12-17-2006 12:12 AM
I have only had one size of coil racks. I have had various sizes of coils and they have always worked well for me. I have had a few instances where the coil touched the bed of the truck, but as long as you have good support from the rack and adequate chains or straps, you should not have any problems.
thejunkman 12-21-2006 03:37 AM
[quote="rank"]
If your that broke where you cant afford 200 bucks in coil racks, then you dont have the experience need to haul a coil. And it takes experience
wot i life 12-21-2006 04:22 AM
If you have never carried coils before, then be bloody careful. Most news reports of trucks losing loads of steel are about coil carriers. Use plenty of chains and a few straps on the bite, counteracting each other, wouldn,t hurt.
Good luck :wink:
rank 12-21-2006 03:10 PM
Okay, I get your point. You're right, I've never hauled a coil and I've read lots of stories about them falling off trailers. But with the proper number of coil racks and chains, edge protectors and mats....how can you go wrong?
Without looking it up in the book, I'm guessing a 20,000lb coil should have 3 6500lbs chains through the eye toward the rear, one in the middle and another 3 toward the front (although I can't imagine what good the 3 toward the front are doing).
Granted, I know nothing but what bothers me the most about coils is the concentrated load they put on the trailer.
Now, flame away. :wink:
thejunkman 12-21-2006 03:20 PM
No flame...actually I recant what I said, short of pulling one, you are looking at the right things. a 46k coil in front of the axles does put a lot of stress on the trailer. Good luck in what you do, and remember more chains are better. I personally think a stepdeck is safer for coils. Plus a 20k coil over the 5th and one over the axles isnt fun either. 20k weight right above the 5th wheel does wear her out quicker than the weight being spread. I agree though, a lot of the flatbed related load problems out there are due to hauling coils. Be very gentle, and dont race. Remeber those 46k coils are also kinda higher up too.
Best Wishes
PS The chains toward the front are simply to keep it stable. If you get any rolling, its very dangerous. You want NO chance for that coil to move. If you load suicide, and that does break loose, it will take a header, a headache rack and the cab out with it, I have seen the trucks with the rolled over sleepers, and they are not nice to see.
rank 12-21-2006 04:41 PM
Thanks Junkman.
Don't think a 46,000 lb coil would pay well enough for me to put it on one of my trailers but you never know. Smaller ones would suit me better.
I hear you on the big coils having the high center of gravity....especially on a flat deck. Our head hauls are 50,000lbs payload with the c of g at approx 6 feet off the ground and that's bad enough. But a big coil on a skateboard must be even worse. S-l-o-w c-o-r-n-e-r-s.
thanks again
nightprwlr 01-02-2007 12:03 PM
Coils
They come in all shapes and sizes. Just make sure the coil fits tight on the lumber in the rack and not on the floor.Depending on the method of unloading or loading,my preference is to haul them suicide/eye to the side whatever. I think they ride better. The biggest one I have hauled weighed about 68,000 lbs. from Madison Il. to Detroit Mi. For the bigger coils I'd recommend using the large coil racks and a beveled 6"x6" oak board approx. 5-6 ft. long to distribute the weight a little better they're just a pain in the rear for storage when not in use but if you haul machinery or other large items they also come in handy for that. Every steel mill has different rules etc. Get some 3/8 chains too at least 6 w/ratchet binders. Good Luck.
Rev.Vassago 01-02-2007 12:09 PM
Thanks for reminding me why I haul HHG. :wink:
traveler15301 01-03-2007 02:50 AM
....sissy!!!!! j/k :P
