-   -   Cat C13 vs Cat C15: why pay more? (https://www.classadrivers.com/forum/owner-operators-forums/22545-cat-c13-vs-cat-c15-why-pay-more.html)
60363 11-24-2006 02:29 PM
Can someone help me figure this out?
According to the Cat web site, they recommend to speck axle ratios and tire sizes like this:
Cat C13, Multi-torque
80,000 lb GVW
430-hp, 1550/1750 lb-ft
1325 rpm @ 65 mph
Cat C15, Multi-Torque
80,000 lb GVW
435-hp, 1550/1750 lb-ft
1325 rpm @ 65 mph
So, basically both of these engines are OK for full truck loads and will run at the same rpm with the same horse power and same torque...
But why should someone pay more for Cat C15 (I assume it costs more money!) when C13 can do the job cheaper, and it weighs almost 800 lbs less? Both engines are designed to run 1,000,000 mi to overhaul and have 30,000 mi maintenance intervals.
Any ideas?
And another question: 2 fully loaded trucks run with the same load on the same road at the same speed, let's say 65 mph. One has a C13, another C15. Both have the same HP, same Torque, and turn at 1325 rpm at 65 mph... same axle ratios ...
Will fuel mileage be any different?
Thanks to everyone for input on this confusing topic :)
Overloaded 11-24-2006 03:06 PM
They may say both are good for 1,000,000 miles before an overhaul, but I'm willing to bet the C-15 would outlast the C-13. That is a very low hp setting for the C-15 therefor it isn't working it's self to death, whereas that is about the max for a C-13. Plus, the truck will be worth more at resale time with a C-15 since it can be turned up to 550+ hp.
solo379 11-24-2006 03:21 PM
Well, the way you put it, it seems that C-13, would be the better choice! :roll:
If that would be 475-1850 C-15, specsed to run, at the same RPM/speed, there would be benefit of extra power, and torque, and engine is not working that high of % of total power, therefore should last longer... , or you'd simply got some extra, in case you need it...
As of to your second question, i'm pretty much sure, it will be about the same, may be 0.1-.2 gpm difference.
marylandkw 11-24-2006 03:22 PM
Hopefully I don't get flammed for this one but here goes....
Bigger Motors get BETTER fuel economy.
That C-13 will be working it's exhaust pipe off to make those numbers.
The C-15 set that low will barely be working.
Now I drive conservatively with a C-15 rated at 550hp with 4.11 rears and an 18speed and get 7mpg all day and night.
I don't know how much a C-13 costs now a days but the spec sheet in front of me for my new truck (should have it in a week or two) says the C-15 weighs 941 pounds and the line item cost is $12,874
solo379 11-24-2006 03:27 PM
Wow! How conservative you are, to get that mileage, at those rears?
Also, didn't want to look at my truck specs sheet, but i believe, you are about 10 grand short, on C-15 price. :wink:
yoopr 11-24-2006 03:32 PM
That's quite a claim
solo379 11-24-2006 03:45 PM
Ok! You've got me curious :D , and i did pull out my specs sheet.
C-15 475 ACERT 475@2100 1850@1200 $9,951 860LB.
That was in 2004, gain some weight and $$$ since than! :sad:
That $$$ number you see, is not represents the whole price of the engine, just an extra, for that particular option.
For example, if you look on your specs sheet, a lot of things(radiator...) is $0. :wink:
marylandkw 11-24-2006 04:07 PM
Well my spec sheet says $12,874, but it also says that the total price of the truck is $186,955, But I did not pay even close to that.
I would love to grab a couple of those $0 radiators :lol:
Lets not forget spec sheets come from dealers, and well, you should not trust dealers.
http://static.flickr.com/122/305455835_7c76bbb062.jpg
Bobby 11-24-2006 10:08 PM
Another thing to consider is what the truck/engine application will be.
If your doing most of your hauling on flat land with lighter loads the smaller engine might be your best option.
Where if your hauling heavy loads in areas with Long grades or in the steep mountains, the extra power of the bigger engine would be the the better option, IMO.
This would also apply to starting and stopping power. The bigger engine will hold the truck back better on grades, and also get a heavy load rolling from a dead stop better, especially if your headed up hill.
GMAN 11-25-2006 12:00 AM
That engine price is hard to believe. It can easily cost more than that for an in-frame. If that is all they cost, then it would be better to just throw the old engine away and buy a new one to drop in when you need a new engine. :shock:
Bobby 11-25-2006 02:28 AM
The way those spec sheets work is you start with a base truck with no upgrades, with it's price and weight.
As you ad upgrades like the bigger engine... it ads cost and weight to the base or generic truck. That's the figures your seeing, Cost and weight over a stock engine.
edit: The zero's represent a standard part included with the base truck, with no increase in weight or price.
My C-15 was 719 lbs over for an 01 model...pre Acert. My sheet doesn't show the cost, but they have gone way up it looks like.
marylandkw 11-25-2006 03:32 AM
That makes sense. That's the good thing about these boards, You can learn something.
Kinda like those new free radiators Solo379 and I are looking for :lol: :lol:
Bobby 11-25-2006 03:54 AM
It will also show a savings in weigh. Aluminum wheels on my sheet (24.5's) showed a minus 46lbs front and minus 184lbs rear over the standard steel wheels for example.
Ian Williams 11-25-2006 04:41 AM
At my work about 3 months ago they turned up the power on our tractors and we actually get better fuel mileage. Here in Reno most of our line runs are going over mountains 80 & 395 or pulling heavy sets of triples.
Now coming home from Sacramento I just get passed by most other rather than all.
RostyC 11-26-2006 12:15 AM
I was getting exited there for a moment, I was gonna order one for my lawn tractor :lol: :lol: :lol:
60363 11-27-2006 03:03 PM
According to Cat's web site these 2 engines weigh:
Cat C13 Cat C15
2270 lbs. 2890 lbs.
Some posts here referred to much smaller numbers.
solo379 11-27-2006 03:21 PM
Cat C13 Cat C15
2270 lbs. 2890 lbs.
Once again, neighbor :) , it was just the difference, between "base" and "optinal"! :wink:
allan5oh 11-27-2006 05:14 PM
Re: Cat C13 vs Cat C15: why pay more?
80,000 lb GVW
1325 rpm @ 65 mph
80,000 lb GVW
1325 rpm @ 65 mph
What's missing is the RPM of the HP and TQ peaks. Also, the c13 might have the same tq and hp, but they may be more "peaky". The c15 will have what drag racers call "more power under the curve".
60363 11-28-2006 02:09 PM
allan5oh
Peak torque for both C13 and C15 in these configurations is the same: 1,200 rpm.
BUT: C13 with 430 hp and 1550/1750 lb-ft of torque shows TORQUE RISE as 44%/63%; its maximum HP is 445; while C15 with 435 hp shows TORQUE RISE as 43%/61% and its maximum HP is 450.
Cat C13 with 470 hp 1,650 lb-ft of torque has 40% TORQUE RISE.
Cat C15 with 475 hp 1,650 lb-ft of torque has 39% TORQUE RISE.
As you can see there's no big difference still.
But:
Cat C15 500 hp 1850 lb-ft of torque has ... 56% TORQUE RISE.
NascarFan 12-01-2006 06:55 AM
A buddy of mine used to own a truck with the C13 @ 430HP and said he constantlly got around 5.5 to 6mpg now he has the same truck just with a C15 @ 435HP and gets 6 to 7mpg.
