-   -   Failed Calif general knowledge test 3 times, yikes! (https://www.classadrivers.com/forum/new-truck-drivers-get-help-here/9674-failed-calif-general-knowledge-test-3-times-yikes.html)
Mandilon 07-09-2005 03:11 PM
I say these THIEVES (Calif DMV) write these tests in a maliciously deceiving way so that they can collect (steal) an additional $60 in fees from at LEAST 51% (the majority) of Calif CDL seekers!
Question # 16) If you need to leave the road in a traffic emergency, you should:
a) Try to get all wheels off the pavement.
b) Avoid braking until your speed has dropped to 20 MPH.
c) Avoid driving on the shoulder of the road.
>>>> Which would YOU have chosen as CORRECT?
I asked:
http://www.testquestionsandanswers.com
for a refund.
Do you think I'll get one?
They claim to have TWO MILLION happy customers!
I'm certainly NOT one of them.
>>>> Will post CORRECT (according to the THIEVES) answer when:
1) At least 100 drivers (if all the votes are pretty evenly distributed)
2) As soon as anyone answer gets 35 votes.
OR >>>>
3) If ONE answer receives 10 votes with the other two receiving ZERO.
THX for your participation, drive SAFE & God Bless you and your loved ones
'.....to continue'
BIG JEEP on 44's 07-10-2005 07:06 AM
well If I remember correctly your supposed to try ,And leave one set of axles on the pavement , so that would eliminate (A) as a the answer ,And if I remember correctly the learners manual stated most shoulders are built strong enough to handle the weight of your truck & trailer so that would eliminate (C) as the answer so I would go with (B) as the answer .
RockyMtnProDriver 07-10-2005 07:13 AM
So, after you have your drivers license and you.
A - park your truck with part of it out on the road and someone runs into the back of it and dies.
B - spike your brakes and loose control of the truck and jackknife
C - drive too far off the road and flip your unit in the ditch.
Are you going to ask for a refund for the road test you took also?
BIG JEEP on 44's 07-10-2005 07:41 AM
A. = 0 votes
b. = 10 votes b) Avoid braking until your speed has dropped to 20 MPH
c. = 0 votes
And the alternate comedy list o answers is :
a) Try to get all wheels off the pavement the best way to accomplish this , would be in using the trailer brake while violently over steering in one direction. this will help in putting your trailer on it's side where it will have the most traction available to help you come to a stop .
b) Avoid braking until your speed has dropped to 20 MPH , Or you have run into something with sufficien density to stop your vehicle .
c) Air down tires as low as possible for greater off road traction (beadlocks are helpfull) ,As this will also alow your tires to better flex over rocks ,and debris found off -road .
Snowman7 07-10-2005 08:47 AM
The obvious answer is A. Of course you want to get your truck completely off the road unless there is no room to do so. It would take quite a while to let the truck coast down to 20 mph and aren't emergencies the reason for a shoulder in the first place? I say a.
Snowman7 07-10-2005 08:50 AM
Now that I read it again I dont like the use of the word "pavement". Off the road and onto the shoulder yes, but off the "pavement" and onto what?
RockyMtnProDriver 07-10-2005 09:14 AM
I use to run down this road in Idaho where the lanes where about 10 feet wide, there was a 6 inch wide piece of dirt, and the ditch.
Get all your wheels off the road there and you have one very narrow truck.
You wonder who writes those tests. Certainly no one who has actually ever driven a truck.
In our air brake manual, it shows a diagram. In the diagram it shows the supply line to the trailer completely broken and massive air loss.
In a caption besides it it says "in this diagram you will see that even though the supply line is broken, the driver can make a control ed stop"..
If you break your supply line, your trailer brakes dynamite immediately. Your wheels would lock up and if it was icy, the trailer is coming up the side of the tractor and getting ready to slap you upside the head.
If it is dry, you will be skidding the trailer tires.
Does not sound like much control going on there.
I showed them the mistake. They still have not fixed it. Bureaucrats
:evil:
BIG JEEP on 44's 07-10-2005 09:41 AM
http://www.revenue.state.co.us/mv_di...incl=handbooks
First visit the above web address then look at section 2:15(e mergencies) then go to the part that describes leaving the road .
BIG JEEP on 44's 07-10-2005 09:47 AM
:evil:
I don't belive the manual said to get all the vehicle wheels off the road . What I understood the manual to be saying is to get as much of your vehicle off onto the shoulder as it takes to avoid an accident ,But try to atleast leave a set of tires on the road ,so you really are''nt trying to drive off the road any further than it takes to avoid collision .
And when it comes to the DMV not up-dating information ,they still list HANGING MEAT as a type of load tha needs special attention yet HANGING MEAT is no longer an issue as it's been outlawed ,But it's still listed as a load that needs special attention in the DMV handbook ( nothing like good up to date info )
ben45750 07-10-2005 11:10 AM
This question was on my CDL test and was also a question I saw in truck driving school, If you leave the pavement you are most likely on a dirt or grass surface with a possible sideways grade. You apply the brakes to stop your done. You are supposed to coast to 20 mph or below (if you can not safely get back on the road) before applying the brakes.
Hanged_Man 07-10-2005 11:48 AM
Re: Failed Calif general knowledge test 3 times, yikes!
a) The mindset should be to get the vehicle out of travel lanes, not about getting off of pavement. This is an obvious incorrect answer.
c) The key word is driving, and it is illegal to do so on the shoulder. Yet another obvious incorrect answer.
b) Assuming that you are not in the travel lanes, you are where the pavement is not as well taken care of. Braking could lead to loss of control because of an accumulation of oil, dirt and what not. Braking also puts more stress on the pavement which is likely softer on the shoulder, making that another reason (while in a big truck) not to brake until being slowed down. A few other reasons; one set of tires may be off of the pavement if you are completely out of the travel lanes, there may be an edge trap between the travel lanes and the shoulder, one set of tires may be on a rumble strip, all of which cause a significant control difference between each side of the vehicle which should not be aggravated by braking.
RockyMtnProDriver 07-10-2005 11:59 AM
I am not sure that wrong and right are the best way to look at this.
I can come up with a scenario where they will all be right and all be wrong.
Which is the best answer?
ben45750 07-10-2005 12:56 PM
B is the correct answer for this question. This was taken out of the Ohio CDL manual:
Leaving the Road. In some emergencies, you may have to drive off the
road.
It may be less risky than facing a collision with another vehicle.
Most shoulders are strong enough to support the weight of a large
vehicle and, therefore, offer an available escape route. Here are some
guidelines, if you do leave the road.
Avoid Braking. If possible, avoid using the brakes until your speed
has dropped to about 20 mph. Then brake very gently to avoid skidding
on a loose surface.
Keep One Set of Wheels on the Pavement If Possible. This helps
to maintain control.
Stay on the Shoulder. If the shoulder is clear, stay on it until your
vehicle has come to a stop. Signal and check your mirrors before
pulling back onto the road.
Returning to the Road. If you are forced to return to the road before
you can stop, use the following procedure:
Hold the wheel tightly and turn sharply enough to get right back
on the road safely. Don?t try to edge gradually back on the road.
If you do, your tires might grab unexpectedly and you could lose
control.
When both front tires are on the paved surface, countersteer
immediately. The two turns should be made as a single ?steercountersteer?
move.
BIG JEEP on 44's 07-10-2005 01:24 PM
road.
on a loose surface.
control.
move.
Yep ,and this is the only answer that counts on a DMV test .
yoopr 07-10-2005 01:36 PM
:evil:
That's like some of the 2 lane highways in Montana-They don't Know what a shoulder is :P
scottybones 07-11-2005 01:13 AM
The answer is "B', as that is the answer.
Mandilon 07-11-2005 01:42 AM
THX guys for ALL your answers!
I liked: RockyMtnProDriver, -"I am not sure that wrong and right are the best way to look at this.
Which is the best answer?"
Be safe & God Bless
"They say" the answer is "B."
I STILL believe at least 51% (52% at this point: 10 divided by 19) miss THIS question MAINLY because of the way 'the whole thing is worded.'
NOTE: By casting my vote, in accordance to my actual answer for the test (I answered 'A') the percentages chenged to: a) 45%, b) 45% and c) 10%.
Fifty-five percent 'of us' got it wrong.
This is good for 'recurring' $60 fees, NOT to help the potential trucker be a safer driver!
ANY ideas how this question could be 're-worded for the BENEFIT OF SAFETY and drivers and NOT the DMV's?'
THX a million!
scottybones 07-11-2005 02:29 AM
Ya never did say what answ your picked. My instructor told us the key word in that question is "should". I'll be taken my writtens today and I hope the hell that quest is on there. 8) -scot
Larry 09-28-2005 11:27 AM
I had to retest 3 times too for my learners permit. I only went to school to eat my lunch, and when I discovered girls all academic pursuits plummeted.
Nailbender 09-28-2005 03:27 PM
I decided that to pass the written tests one needed to turn off his or her common sense software during the test :lol:
In the South Dakota cdl manual they say the best way to get back on the road after going onto the shoulder if there is a slight ledge is to turn the wheel sharply until the tractor is on and then countersteer sharply to get straight on the road.
I think that is hooey and a good way to find out what a roll over is like.
But then I am just an a ordinary citizen, what could I poosibly know :shock:
Hanged_Man 09-28-2005 03:51 PM
The same effect will happen regardless of the vehicle. You'd damage the tires if you scrape their walls along an edge even if the tires are shaped perfectly vertical but they are not, they puff out at the bottom which will increase the damage. Also you might remember an incident in your youth attempting to maneuver your bicycle onto a curb. It just can't be done if the angle isn't sharp enough. On your bicycle, should you increase the pressure on the curb without a big enough angle you'll be flipped over. In a truck, (while your tires last) you'll get bumped back to the lower side over and over until you increase the angle enough to climb ?the curb?. This is what gets them the name of ?edge trap?.
Frenegade 09-28-2005 10:02 PM
Took my wriiten last week (passed) I soon discovered that apparently
the authors of the exam slip in quite a few questions that seem to
ensure that you have read and studied the CDL manual, not just the
test questions and answers. The FL test has a number of them, where
you could have easily argued the validity of answers other than the
correct one. The correct ones were easy to spot, as they were
verbatim from the manual.
My advice to others. When you study the manual, the "foot stompers"
will jump out at you especially if they quote a number.
Tim
Jimbpard 09-29-2005 06:10 AM
Thats EXACTLY what my dad said.... :roll: :lol:
Jimbpard 09-29-2005 06:21 AM
Mandolin, sorry to say it, but i think you were rather foolish to PAY for the answers and questions when there are sereval internet sites that have full practice quizes.
I practiced for mine at http://www.cristcdl.com/otc/ at passed first time. And yes, the question you presented to us was on the test I took. Its my understanding that the federal gov't makes up thoses tests. Not each state. Therefore, they are all the same. Make sure you study ALL pages of the general knowledge test, along with ALL pages of airbrakes, combination, and pre-trip. You will have a MASSIVE headache (I did), but you WILL pass the permit test, and thats all that matters. I remember that on that website in the general knowledge part, it looks like its turning into a School bus test, but keep on doing all the questions. If you dont you'll be sorry. Study them till you know them all 100%!!!!!!!!!!!!! Dont miss any! Like I said, most important, do ALL pages of general knowledge.
Hope I helped.
Good luck.
