If you actually care....read this...
I have seen on our bulletin boards in our terminals ....that as of May 11, 2009, the USDOT will be using GPS data from OBCR data to audit logbooks.
So it appears that the USDOT is going to compare your GPS input from your OBC against your logbooks to define whether or not you are running legal.... Best be safe than paying fines..... |
This is old news. Many companies who use Qualcomm already do this.
It has been what...at least a year now since they changed the rules and no longer have to get a court order for things like Qualcomm records.
Ahhhh, but prior to this....they were not doing so. Apparently they have decide to do this, and it will become fully active as of 05/11.
I am thinking that companies may be required to "ping" their trucks more than once every hour.... I noticed that the other day....even though I had my tank washed out after a HM load, that at 0530.....while I was in the sleeper berth....my geologic screen "lit up"....after the truck had been shut down (engine off 9+hrs)....so I can only presume that I was "pinged"..... While some might claim its nothing new....it really is, because they will now be using GPS coordinates to validate the logbooks......... whoo-hooooo. Should be fun..... Where's my "tinfoil hat".......:eek1: |
(Post 449554)
Its a different set of parameters, or a different "paradigm" if you please....:cool: |
Originally Posted by Skywalker
(Post 449561)
I am thinking that companies may be required to "ping" their trucks more than once every hour.... I noticed that the other day....even though I had my tank washed out after a HM load, that at 0530.....while I was in the sleeper berth....my geologic screen "lit up"....after the truck had been shut down (engine off 9+hrs)....so I can only presume that I was "pinged"..... While some might claim its nothing new....it really is, because they will now be using GPS coordinates to validate the logbooks......... whoo-hooooo. Should be fun..... Where's my "tinfoil hat".......:eek1: The Pilot, Petro, and Flying J actually sit in Middlesex Township,PA. |
DoubleR... You're right it will be interesting once they start doing it....there are any number of discrepancies that will pop up....and one has to wonder what the time variation is that they will allow.... Those of us that know....due to reality, that the best you can do is 15 mins +/- on paper....so it remains to be seen what standard will be used...................
And in the meantime ...we get blamed for everything between the lack of taste in Wrigley's chewing gum and the the inefficiency of Cuba's government......:roll3::smokin::bow::mad::moon: |
(Post 449567)
And in the meantime ...we get blamed for everything between the lack of taste in Wrigley's chewing gum and the the inefficiency of Cuba's government......:roll3::smokin::bow::mad::moon: People Net is cell tower based, so the nearest tower could be as far as 9 miles from you:D(That's the furthest I have see so far) . Lets see how long it takes safety to catch on.:D |
Originally Posted by Double R
(Post 449569)
Agree. And now that I have to use a log book again since I travel pass 100 air miles(in a day cab), I just write down what is on the "PEOPLE NET" screen.:D
People Net is cell tower based, so the nearest tower could be as far as 9 miles from you:D(That's the furthest I have see so far) . Lets see how long it takes safety to catch on.:D Yep...its amazing.....and some companies are going to find out that is "NOT business as usual"....and compliance is gonna be the name of then game.... I think its gonna be like an "inadvertant" restructurant of the realm...... |
Sure glad we do not use qualcom or any other tracking device!!!!
Originally Posted by Pack_Rat
(Post 449574)
(Post 449574)
Quite honestly, this is a BIG intrusion into privacy. Any system that can be abused, will be abused, now we have the government tracking the majority of the trucks on the road under the guise of compliance of HOS regulations. Also of note is that though GPS technology has come a long way in the last 20 years, it still has issues. Though it is rare, the government does shutdown the satellites from time to time, or limit them, for purposes of maintenance, realignment, and military exercises, and they usually do it with little to know warning. Also solar flare activity can and does interfere, as well as natural magnetic field activity, and man made interference. You don't always notice these anomalies while driving down the road simply because consumer GPS devices such as navigation systems, use special subroutines to guesstimate actual location when a signal is not as it should be, but that requires the GPS to be on and tracking for a time period to have the proper data to do that. If you just processed raw GPS signals and had it represented on a map, it would be bouncing all over the place within a 1 mile radius of where you are really sitting, and if any of the above mentioned anomalies are going on, that bounce can go as far as a couple hundred miles! I know this because I have done programming with GPS systems before, and I had to learn how to code the subroutines that 'stabilize' the signal to give more accurate result. So the real problem here, is if the location is only being recorded every 'x' amount of minutes, the GPS is not 'stabilized' and can give very erratic results. Even if it was say every 15 minutes, it will still usually be accurate to within about 20 feet, BUT you will get those anomalies from time to time that will show you being 200 miles away from where you are, which I would venture to say could happen probably every 100 'pings' or so, but that could vary widely based on where you are, solar flare conditions, etc. Honestly I do not forsee too many issues with accuracy, but they will occur. |
Originally Posted by wsyrob
(Post 449584)
If you carry a cell phone and have it on while you drive you can be tracked. Have a wreck and those records will be used against you.
Originally Posted by matcat
(Post 449586)
Cell phone tracking is an iffy subject, unless you have location turned on (all phones have this option, it is required by federal law), the network has no access to the phones GPS tracking unless you are connected to a 911 center, and no records are kept. However cell tower triangulation is constant, BUT it is very inaccurate for location, and cannot give speed data at all.
True but it sure could screw up the double log book/phantom team driver types that were several hundred miles away from where they said they took a break. |
Just wait until they get the EOBR's. If successful we will all need to buy these recorders so we can be tracked. Big brother at work.
Our safety dept reminds of this every now and then.
Our dispatch/planning dept also has a electronic map that looks sort of like air traffic control, It shows where you are, ...if you are running on time...and will trigger a 14 clock if you move the truck more than 1500 feet. Oddly enough...if it comes down to a service failure...or the 14 clock... they have been known to 'overlook' the clock. Go figure |
Originally Posted by GMAN
(Post 449610)
Originally Posted by zipy46
(Post 449615)
Its a pisser...:(
I used to show up here at the board ranting about forcing these companies to play straight pool and run their drivers legal so we would not be framed to take the fall for them... All my wishes have backfired...! This legal pressure has simply taken the definition of 'Forced Dispatch' to a new level. Where I work for example you have basically relinquished your log book to the planners... You run when they say you run...7 times out of 10 its on little sleep and running all night and into the morning. ...be careful what one wishes for they told me when i was little |
The secret to trucking is being able to sleep in the day like one of those creatures
you see on Wild Kingdom :) |
Since the FMCSA lifted the ban back in Feb 09, my company has been making us run in compliance with peoplenet. Its not just qualcomm, its ANY device that can be tracked that was installed by the TRUCKING company. I went from running 3500-4000 miles a week down to 2000-2700. Friday night I hit Kingman,Az at 1930 and had to shut down for my 10. What sucked is that 1. I wasn't tired and 2. I was 2 hours away from home. I have to leave tonight around 1800 so I can get to Phoenix and take a 10 so I have my full hours for tomarrow. IMO, the feds can crack down on companies all they want about drivers running legal, but until the SHIPPERS are held responsible for a truck sitting in their docks for hours on end....it won't make one damn bit of difference. Thankfully I only have a year left driving and then I'm out of the trucks for good, wife is going to school for her RN and she wants me home.:clap:
You guys that are getting out of trucking...or have gotten out make it sound as if you've
escaped Alcatrazz itself... Its very inspirational for me. :) There is hope |
My wife and I won't be far behind you other guys who are leaving this industry. We are downsizing on our house and have very few bills left. I will gladly great you all at Wal Mart before I continue in this business.
I quit driving just under 2 months ago and don't miss it one bit. I've went back to work doing construction. Even though it's a lot harder work, I'm sooooo much more happy. Plus I live on a normal schedule now, not deliver at 6am after driving 8hrs, sit at a dock for 3 hrs, drive 2hrs to the next pickup, sit another 3-4hrs getting loaded then be expected to drive another 8hrs.
Until the industry gets it into their thick skulls that drivers aren't robots and shouldn't be expected to change their sleep schedule every 15 minutes, it's going to continue to be the way it is right now. The shippers and receivers don't care - they want their product sent on their schedule. The dispatchers don't care - they're not the ones sitting in the truck all day. The DOT doesn't care - they have the rule book in front of them. The only ones that care are the ones that are getting the shaft. I've quit driving before and this time it's so much different. Every other time, within a week or 2, I'd be on the interstate and see a truck and long to be back behind the wheel. This time, I want nothing to do with a truck. I don't even want a local driving job where I'd be driving a dump truck. I've turned down a lot of offers for driving local, but I know I'd be miserable again. I'm probably going to go to a trade school and work on doing electrical work. But driving truck again - probably never again. |
Originally Posted by Malaki86
(Post 449798)
hahaha - thank you
Personally...I think that there are going to be a lot of people leaving the industry. With the new and additional use of the GPS tracking to audit logbooks.....there are going to be a lot of heads busted by safety departments, and who knows....the Fed might be planning on using this as a new method of "revenue enhancement".....they will certainly be able to nail some companies that aren't really running legal.... Dispatchers will have to pull their heads out of the butts and make sure drivers run legal....or the fines on the companies will cause the ownership to redefine the "business model"....
I think its gonna be interesting......:cool: |
(Post 449798)
Until the industry gets it into their thick skulls that drivers aren't robots and shouldn't be expected to change their sleep schedule every 15 minutes, it's going to continue to be the way it is right now. The shippers and receivers don't care - they want their product sent on their schedule. The dispatchers don't care - they're not the ones sitting in the truck all day. The DOT doesn't care - they have the rule book in front of them. The only ones that care are the ones that are getting the shaft. I've quit driving before and this time it's so much different. Every other time, within a week or 2, I'd be on the interstate and see a truck and long to be back behind the wheel. This time, I want nothing to do with a truck. I don't even want a local driving job where I'd be driving a dump truck. I've turned down a lot of offers for driving local, but I know I'd be miserable again. I'm probably going to go to a trade school and work on doing electrical work. But driving truck again - probably never again. :bigclap: Good point Mal. |
(Post 449563)
Your right, this will be fun. Especially when my "PEOPLE NET" shows me in MIDDLESEX TOWNSHIP,PA and both my log and fuel receipt say CARLISLE,PA.
| All times are GMT -12. The time now is 10:02 AM. |
