What works for power steering fluid?
What other type of fluid works for power steering fluid in a big truck?
is it brake fluid or transmission fluid?
Automatic transmission fluid......
power steering fluid works real well.
Originally Posted by Fredog
(Post 439965)
It should say on the power steering reservoir what the "Approved" fluids are.
Most of the time it is automatic transmission fluid. I've been told (not confirmed) that if you mix transmission fluid and power steering fluid you will void any warranties because it causes seals to go away. |
The freightliners I drove previously- were set up to use 10w-40 in the power steering- One fluid for everything.. nice thinking.
The Volvo 670 I'm driving now calls for Mecron-Dextron II Transmission fluid, Back home, I use Type-A Transmission in the Pickup and Cars. In older days-- there was no power steering in semi trucks-- you just used a bigger 25'' steering wheel and more elbow grease. That's one of the reasons- drivers were taught to always park with their wheels straight(finish a maneuver clean)... because you had to be rolling to easily turn the wheels. |
In an emergency any oil is better than none at all, but try to use the oil or fluid specified by the truck manufacturer or the power steering system manufacturer.
NEVER USE BRAKE FLUID!!!!!!!!!!!!! Mack specifies 15w40 engine oil in their power steering systems, there was a reason for that: If the input shaft seal on a flange mounted spline driven pump should fail, the oil is the same in the engine and the power steering system, so there would be no "cross contamination" issues. International specifies their own brand of power steering fluid in theirs. |
Power Steering Fluid?
What Headborg said, 10W-40, that's what my Cornbinder likes per the company maintenance bubbas. BOL
Originally Posted by Flashmann
(Post 439968)
Yup........But since the original question was what OTHER fluid works,I answered,hopefully,before he used brake fluid......
if he is just curious about what other fluids will work then he got the correct information. I still try to always use what it calls for on the spec tag |
(Post 439962)
Originally Posted by Nevermind
(Post 439954)
Originally Posted by headborg
(Post 440028)
I have used automatic transmission for many years and never had a problem.
| All times are GMT -12. The time now is 05:35 AM. |
