Noise levels inside the cab
How noisy is it inside the cab with the windows up both from the engine and from road noise? Is it loud enough to be able to cause eventual hearing loss? In some of the Youtube videos I've looked at it seems pretty loud and in others, not so much. I've heard that the newer trucks have sound insulation that keeps it fairly quiet. I like quiet.
What?
Sorry couldn't resist. |
A noise level preventing normal conversation for hours and hours will damage your hearing. If you add a radio, CB or CD, your environment is even louder. In a factory, you would be required to use hearing protection. In a truck, simply turn off your hearing aids.
The noise level inside my truck is horribly loud. Then again it has very little sound insulation. I don't answer my phone going down the road, not just because it's dangerous but I can't hear the other person so it's a waste to answer it.
its pretty loud in a mack daycab, sleeper no so much
In my Volvo, I can have a normal conversation either on the phone or with my wife when she rides with me without any problem.
Some trucks are "louder" than others, but in no case should the ambient noise level inside the cab be enough to cause premature hearing loss. The better insulated and tighter the cab "seals up" is the main factor.
The other thing you have to remember is the microphones on those camcorders tend to concentrate and amplify noise they're picking up, so you will get an impression of more noise than there is actually is in there as a result. The noisiest in the cab truck I ever drove was the 1989 Kenworth K100E I drove on my last gig as a truck driver. Hottest too, since I was sitting over the engine...a big plus in winter though! |
with the new 09' volvo swift assigned me with a couple weeks back. the noise level is much lower than the previous 05' volvo i had. while i'm driving, it's still much more quiet. i can finally sleep in this new truck. the old one's engine noise was a bit too much, and it didn't help having cabinets inside that would rattle non-stop.
WHAY WAS THAT YOU JUST SAID??
Hearing loss is accumulative. I'm 51...my hearing loss started in 1970........when I drove my first farm tractor. Over the years...I have driven some pretty loud trucks, worked some very loud equipment..and I have worked in some very loud exterior enviroments as well, refineries, chemical plants, power plants and on oil wells. Standing beside a busy city street is bad for your hearing. It isn't the loud noise......it is the ultra-low frequency that bites you. |
We primarily drive 05 Columbias (daycabs) and even though they are all the same model, some are louder than others. It seems that those daycabs have no insulation whatsoever. They are very loud, plus it seems that even though the window is rolled all the way up, it still has a nice whistle. Not to mention leaky windshields.
The most quiet truck I drove was the 09 Int'l Prostar with a sleeper. Talk about a smooth ride. I was quiet like a Cadillac compared to those daycabs. My next door neighbor is an audiologist. I'll ask her if cab noise can cause hearing loss. |
I took one of those hearing test in one of those mobile units and the guy told me that truck drivers often show more hearing damage in the left ear due to driving with the window down for long periods of time.
Perhaps today's drivers will not experience as much hearing loss as the old-timers. I drove Cracker Box Jimmies powered by two-cycle Detroit Diesels. During a lunch break, I could not hear the waitress until it was time to order dessert. Mack came out with their Maxidyne and 5-speed. The turbo had a whistle that was really irritating. A deer warning device can also be very irritating if it is mounted near the driver's window. Some of the highway noise we hear today is from the tires. Tread designs trap and release air against the pavement.
Now...the Maxi's...those were a real screammin meemie!! Almost as loud as the old Allison's. The Allison's let folks know they were coming for miles, before the truck got there....but damned if the truck wasn't flying when it went by. Mostly Autocar trucks had those...engine compartment and hood design worked for them and all the crap behind em. |
I drive a 06 mack granite and it is not bad at all. But when that fan kicks on you can hear it for miles. Alot of guys think trucks aint loud enought thats y they stright pipe them. If i was aO/O that would be the 1st thing i do is throw them junk mufflers away.
Originally Posted by Malaki86
In my Volvo, I can have a normal conversation with my wife when she rides with me.
:lol: :lol: |
For those of you that drive loud trucks and care about preserving your hearing, even if you already have some hearing loss, you should consider buying some disposable foam ear plugs. They can be comfortably worn for long periods of time whether driving or sleeping. The same pair can be worn until they start to get dirty which usually takes several days. They are inexpensive and are sold at Walmart among other places. They don't totally block out noise but cut the sound down to safe and comfortable levels. And they are preferable to the hearing aides you may end up wearing if you don't use them. It's just a thought.
I don't need to "buy" no cheap-o foam ear plugs!! Every single plant I go into, has them available to me for FREE!!! Some of these plants give out some really classey ear plugs too! You should only wear foam plugs for the one day of use. You risk severe ear infections using them over and over. |
I never drive with my windows down on the highway. It only took one big bug on my cheek to end that practice :shock: :D
So, you're saying you spit and not swallow? :lol:
At the trucking co I work for, the girls in the office have soft voices, and I just pretend to hear what they say. But the truckers all yell at each other. I love it, since I can HEAR them. I had some hearing loss even before going into trucking, but even so, to save what I have, I take a pair of decibel-lowering earmuffs in the cab, and I put them on when the noise gets to be too much. Same hearing protection you see at a firing range. Some long grades uphill on a certain type of road surface just rip my ears up. A cop once asked me if I wore the ear protectors in the truck, and I said I just use them for lawn mowing. I got a ticket anyway, but not for the ear protectors.
I drive 2005, 2006 volvos. They sound pretty loud to me, but they are supposedly not too bad, compared to other trucks. I tried earplugs, but they irritate my ear canals, and I don't want to get an ear infection. I've noticed that folks who work in the trucking biz automatically raise their voices quite a bit, during conversation. I guess they assume everyone has some degree of heraring loss . |
As for the original question...I'm sure 50% of people on here would say "yeah wear ear protection" and all that. Get the heIl out of here. The day I have to wear ear plugs going down the road is the day I need put in the grave. Cab noise is not much louder than a pickup with a big motor. JMO |
my cab is very noisy. I like it that way. it keeps me awake. :lol: my hearing was never too good & I like it that way cause I have awife & 4 girls :lol:
I seem to remember an audio engineer turned driver who took db readings in and outside of the truck and listed the results somewhere within this board. I can’t locate his previous posts but they were fairly detailed from a scientific perspective. Does that sound familiar to anyone?
Next job I had the AC went out, and a wasp came in and stung my arm.. So since I am a slight allergic to Bee Stings I would have accepted the bug on the face much better. |
I drive a 05 Freightliner and i can barley hear my phone ring
Sterling
Most of the trucks I have driven are pretty quiet in the cab. I like the 07' T600 and the 07' 387 pete. Both trucks run and look great.
I currently drive an 07 sterling and I must say this is the worst truck i've ever driven. The noise level is horrbile and the transmission sucks. Sterlings are nothing more than a work truck. No comfort features. Lucky for me I am only in it 8-12hrs a day. |
| All times are GMT -12. The time now is 03:55 PM. |
