Graymist |
06-06-2008 08:27 PM |
Originally Posted by wildkat
Originally Posted by Graymist
Have any of you guys tried neutral-shifting while splitting, with your 18-speeds ?
VERY BAD idea Graymist, you can tear the splitter apart...PRE-SELECT all shifts, both range & splitter. :D :D
Interesting that you should say that, Kat. I, personally, have tried to do it a few times, with an empty single trailer & never with a super b, and ended up grinding the gears horribly, and that was the end.
I was told about this technique by one of our senior guys who does a lot of cycloning in the bush. Apparently, as per him, that's the way all the guys in the bush shift gears, in order to ensure that the gear never slips, once it's shifted into a selected position, especially in winter.
