-   -   How to keep windshield washer fluid from freezeing? (https://www.classadrivers.com/forum/new-truck-drivers-get-help-here/32724-how-keep-windshield-washer-fluid-freezeing.html)
Danisawannabe 03-02-2008 07:15 AM
A newbe to winter driving asks...
While drivng in cold enough temps the light roadspray/mist in the air will freeze into a thin white sheet on the windshield. Using the windshield washer will remove it, but the the fluid in the washer tubes freezes up. That means either stop and clean ithe windshield or get behind a truck so the heavier spray gets on my windshield then run the wipers.
Now to the point, the saftey dept. says add alchohol to the washer fluid. No not the good stuff :D just isoproprul.
What about chemical reactions?
Does this work? Or was someone pulling my leg?
Add at what ratio?
Yes, I know low temp washer fluid is available, but if the ratio is low enough then the alchohol is cheaper since I can get free washer fluid from the shop (the kind that freezes).
Thanks for any help,
Dan
BTW ... Yes, I do read/search the posts on poor driving conditions and will likely be the slower truck in the granny lane during poor conditions.
thebaldeagle655 03-02-2008 07:20 AM
I have found that the increased visibility of a good windshield washer fluid is worth the cost when compared to the free stuff I can get at the shop. I have ran Rainex in mine since it was new last May. Have been down to -12 and has not frozen, clears the windshield much better than the blue stuff with much better visibility. I had one of our drivers in the truck with me 2 weeks ago while it was raining and he was amazed at how clear my windshield stayed in the rain.
thebaldeagle655 03-02-2008 07:21 AM
Side question though, why is it that when you have a windshield wiper go bad, the drivers' side always fails first?
fireman932003 03-02-2008 07:25 AM
Yes, I use the alcohol method. I just pour a little in there and see what happens. If it still freezes I just add more till I get it right. I have used as little as a quarter bottle before and I have used a complete bottle before. But, It still is easier just to spend the extra money and buy the fluid that is rated for low temps.
Danisawannabe 03-02-2008 07:32 AM
That reminds me, time to put on the new wipers I bought. Better ones than the shop will provide.
Dan
Fredog 03-02-2008 07:35 AM
the same reason toast always lands butter side down
BigDawg 03-02-2008 07:53 AM
go to Wal-Mart get a jug of the Rain-X windshield washer fluid cleaner it is kind of pee green yellow color,it is alot better than that blue crap and only bout .75 cents more but it work's great.It clrans the windshield alot better also
ogre999 03-02-2008 10:12 PM
:lol: Rumor has it ....some guy named "Murphy" is responsible ...
ogre999 03-02-2008 10:14 PM
cool ...thanx guys ...Ill use it in my POV also ....
Mackman 03-03-2008 05:03 AM
the Rain-X stuff works really really GOOD. It is the best out there. I drive for a guy in the winter time that has 3 tri axles dump trucks and has plows on them and we plow for penndot. With rain-x and winter wipers we never have to get out to smack the wipers. and the windshield stays kinda clear. With snow coming off the plow hitting the windshield.
GMAN 03-04-2008 01:33 PM
I usually just go to Dollar General or some other type of discount store and buy rubbing alcohol with the highest alcohol content I can find. It usually doesn't take that much to keep the fluid from freezing. It also helps if the trailer brakes freeze. Pour a little in the air lines, pump the brakes and use all the air devices in the truck and everything will unfreeze. You can often find a bottle for about $0.59. I prefer putting some Dawn in water for my windshield fluid and adding alcohol. It works better and costs less than the premixed fluid available at most retailers.
