-   -   Hearing Loss from Cab Noise ??? (https://www.classadrivers.com/forum/new-truck-drivers-get-help-here/30735-hearing-loss-cab-noise.html)
BIG JEEP on 44's 11-17-2007 08:18 AM
I can't rember the exact DB level at which hearing damage takes place ...But I have yet to be in the cab of any truck that was what I would consider loud ,as the noise I do get in the cab is at most the same volume as normal conversation , Which is not going to cause hearing loss ...I can't speak for modified trucks or old trucks with nosier cabs , But I have driven the following pete 387,379, KW T-600 Freightliner Classic and Century , and none of these had any notable cab noise at a DB level that would contibute to hearing loss.
Jimbpard 11-17-2007 09:18 AM
Originally Posted by terrylamar
What did you say, I didn't quite hear? If I go deaf it won't be from cab noise, but from playing my music too loud.
Same here.
Larry Heyns 11-17-2007 12:32 PM
I would use ear plugs, the type required in many factories, but it is too late now. If you use them, be sure the low air warning buzzer is loud.
golfhobo 11-20-2007 05:23 AM
I wish you guys would use all caps, or boldface type. My eyes are getting bad, and sometimes, I can't hear a word you are typing! :wink:
ohiomohawk 11-21-2007 02:46 AM
Yes, I use to work at a Tool and Die shop and we were tested once a year for hearing loss. I had hearing damage in my left ear and they guy who tested asked if I drive with my window down often. He also added that truck drivers he tested often had hearing damage mostly in thier left ear due to driving with the window down.
rcpilot 11-21-2007 05:33 PM
Originally Posted by Night Zombie
Hmmmm... maybe those little plastic earplugs that supposedly reduce the noise by only 30 decibels would be legal. You could still hear any loud noises.
I just started using a pair by AO Safety, I can still hear everything just sounds muffled (sp) but the wind noise is gone! When I take them out as I pull into a scale or stop I notice that the cab noise is quite loud now.. They are helping alot :D
Orangetxguy 11-22-2007 01:57 AM
WHAT'S THAT YOU SAY ???? :wink:
