Going for road test in Mack today
Subscribe
Sorry for asking the question so late, but I'm going for a road test today in a newer Mack tri-axle. Assuming its a 10speed.
So far, I have no troublr with any freightliner or KW 10speed, but was a little worried about taking my road test today.
Are they really any different shifting as far as timing go's?
I just read the post about the guy notbeing able to shift from lo to 1st, but felt that didnt really pertain to my question, as I dont really plan on using lo.
But also, what gear should I be able to pull out in (being empty)? I know with a empty 53' I can pull out in 4th, but I've ever drove tri-axle before.
Any help is appreciated.
It really depends on how the truck is geared, and what kind of power the engine has as to what gear to start in.
On a 10 speed, empty, you should have no problem starting out in 3rd regardless.
theres a good chance that it is a 8LL. not a 10 speed.
I also doubt its a 10 speed, never seen a 10 speed in a tri-axle dump before.
Usually 8LL or 15 speed or 13 or 18 speed
http://www.macktrucks.com/assets/mac...specs/t310.pdf
http://www.macktrucks.com/assets/mac...10m1361311.pdf
On a Mack you could also run into a 7spd not to hard to shift since you only have 5 road gears.
so did ya pass :?: :?:
