-   Food & Health (https://www.classadrivers.com/forum/food-health-30/)
-   -   Truck cooking 101 (https://www.classadrivers.com/forum/food-health/15005-truck-cooking-101-a.html)
perchmouth 07-17-2008 06:37 PM
I'm going to be working for Roehl (OTR), and I'm assuming I'll pick up this info during orientation, but I'm curious how this all works and am feeling kind of clueless. I'm not sure what a cab can accommodate space-wise, but I saw some pictures of someone elses truck, and based on what I'm thinking I saw, I'd like to bring a laptop, small TV and microwave. Is that realistic? Maybe even a small crockpot. Can you actually put in a small refrigerator? If not, what are can be used as an alternative? And in terms of those inverters, what do you recommend I pick up in order to accommodate those appliances? The only appliances I envision using at the same time might be the laptop, crockpot/microwave or TV. Such as watching TV while I'm cooking something in the microwave or using my laptop, etc.
Thanks!
Fancy_Maneuvers 07-26-2008 12:53 PM
Originally Posted by Phantom433a
My company only allows 300w inverters....too many braindeads burnt up trucks. Between my cellphone, laptop and speakers, I only use about 75w. Walmart has a small 2 qt crockpot that uses 100w and cost around $10. I use the 12v 5 cup coffeepot, lunchbox and pizza oven by Tracker as well. The coffeepot takes about 15 minutes to brew, but you can use that time for a post-trip. When cooking wth the oven or lunchbox, I usually give 30 minutes for cooktime.
My setup is similar Phantom433a, except I use the saucepan instead of the oven. I don't remember why I switched... But I love my little saucepan so much! I usually pick up Lipton pasta or Lipton rice that is already seasoned; I eat these at home, too. I toss Tyson chicken in with it; this chicken can be found in the bags on the canned meat isle. Also, I might buy a bunch of small cans of vegetables, i.e. English peas. I turn it into a meal when I'm not being lazy.
It is great for a single person on a truck, but I would probably have to do something else in order to fix dinner for a guest. Since it's work, I usually don't worry too much about having guests over for dinner 8)
I also have the 300 watt inverter. I let my laptop charge while I'm driving. I charge my earpiece and my cell phone overnight. When I'm ready to scan bills of lading, I unplug something and hook up my all-in-one printer (unfortunately, I have to buy another one since I recently broke the scanner :sad: ) My company is against inverters, too, so I don't go over the 300 watts. I wish I could hook an iron into it though.. or find one that will hook into a cigarette lighter...
Tony TnT 02-07-2014 03:06 AM
First I would like say George Forman grills are garbage. they can't pan fry.
The coleman propane 2 burner grill. 2 thumbs up. That's my choice in warm weather. But you must never use them in truck.
I have seem the propane gurgle and spurt tall flames. So always, always out side with them.
Cool thread here. Hopefully I can help out.
Back in the day I worked in the repairshop and learned that you cook a lot of things in/on a pizza oven. the new guys use the spinning open air pizza cooker but I like the the silver square pizza oven. I could cook breakfast lunch and dinner in it. For eggs,bacon I would put some foil on the grate and that would work. Not ideal but it worked.
The shop manager didn't like my cooking skill until he got some of that bacon. then I turned into "Whats cookin!"
Nowdays I don't work in the shop and I drive.
I upgraded to more specialized gadgets. Less messy and Easier to clean.
2 PIC induction cook tops from on tv (Lower power version, not the big 2,000watt units. that's over kill)
3 Teflon 8inch pans ($8 each/thin disposable type)(I get a new set every year)
Medium toaster oven(Fits a full size frozen pizza)(Best gift I ever got as far as cooking)
For power you need to have a dedicated 5,000 watt inverter to run them all without over heating.
If you have a microwave(Not Me Any More) you might have to bump the watts up 500-1000.
Ill say again that's only if your running all of it together at once on HIGH.
Running only 2 one on medium and one on high, and the other is off, you can getaway with 2,500watt inverter.(That's what I have)
As far as wiring it in. Don't do it unless your are trained in that field. you could burn down the whole truck if installed wrong.
You must use the proper wire, in line fuse (Real Biggie), wire protection and routing(last thing you need is a wire hanging around the pedals).
It takes some experience to wire stuff in right. Just ask my old buick that went up in flames from poor wiring of a stock radio.
Cant stress enough. have it installed by a pro. Higher power means more safety precaution.
OK that's it before I get off topic.
I'll try find some links for what I have and come back and post em.
Maybe some simple but delicious cooking directions later too.
classadrivers.com/forum/food-health/38955-any-vegetarian-vegans-here-how-do-you-do.html
Tony TnT 02-07-2014 03:10 AM
For those that can not use inverters ill see what I can dig up for dc items. they are making a lot headway in that tech field.
My first idea is JC Whitney. I remember they had almost everything imaginable in dc products. Cheep too!!
