-   -   Disabling the auto shift on a super ten speed (https://www.classadrivers.com/forum/anything-everything/29731-disabling-auto-shift-super-ten-speed.html)
Fredog 09-18-2007 11:46 AM
Well, I finally learned how to do it when I had to drive one that hasnt been unhooked. what you do is shift the gears until you get in 9th, as soon as it starts to shift into 10th put it in neutral and let the clutch out, watch the tach, it will stay revved up for about 20 seconds or so, when it drops back down to idle rpm, shift it back into 10th, it will now be manual shift from 9th to 10th until you turn the key off.
Fozzy 09-18-2007 02:14 PM
Re: Disabling the auto shift on a super ten speed
Why would you want to do that when all you have to do is shift it manually or turn the cruise control off?
Fredog 09-18-2007 02:23 PM
because it shifts by itself, that's why it's called automatic, the cruise has nothing to do with it, 9th and 10th shifts automatically. it is a pain because it shifts when you dont want it to and it takes a long time to shift..
Fozzy 09-18-2007 02:35 PM
I realize that, I just am pretty sure that to disable the top2 function, you have to have the cruise off.. I'll snoop around, But I really do not think that killing the top 2 function requires a lot.
Fredog 09-18-2007 02:47 PM
well, I been driving it for 2 weeks and thats how Peterbilt told me to do it, its pretty simple, you only have to do once and its good until you turn the key off , it doesnt matter if the cruise is on or off on the one I am driving now, th emechanic unplugged it on my regular truck so its manual all the time, but it spun a main bearing so its down for a while
Collard Greens 09-19-2007 03:35 AM
With my super ten auto top two. Before it tries to shift to tenth I push in clutch and put in neutral continue holding clutch til it stops purging abut seven to ten seconds. Then you can shift it manually from 9th to 10th.
Fredog 09-19-2007 03:38 AM
I guess its pretty much the same thing, I just put it in neutral and leave the clutch out.
Collard Greens 09-19-2007 03:45 AM
10-4. 8)
