Lost fuel cap!...
The other day I forgot to screw the fuel cap on tightly enough on the sweeper, and the next day when I returned to the pump, I found it missing! I do not know where it is, so I stuffed a rag (which has gotten diesel on it due to it splashing a bit on bumps) so maybe it will keep dirt and rainwater out. (It's parked under a shelter, but the rain could get in if the wind was blowing in the right direction.)
Is there a website where I can order a new fuel cap? Is there some sort of a serial # somewhere on the fuel tank so that I can use that to determine what size the cap should be? Thnx. :x :oops: |
Re: Lost fuel cap!...
Thanks. The diameter is half the length from one side of the hole to the other and the radius would be the entire length, right? (Been awhile since I brushed up on my math :oops: ) Would it be best to just lay a ruler across the top?
Nope radius is from center to the outer edge. Diameter is the entirewidth. Circumference is the all the way around it.
You also have Pie r squared = area inside the circle. :lol: |
measure all the way across
Most truckstops have them... or they did...
Or.....get one from a parked truck. :P
Just kiddin, dont do that. I tried to search for one online, but as usual, I found everything, but what I was looking for. :roll: I hate searching for stuff online. :P |
http://www.barjan.com/SearchResult.aspx?CategoryID=201
These barjan products are normal truckstop fair.. you could also stop at most any dealer and pick one up, but they usually are dearly priced!!! |
Oh yeah. Barjan. Duh!!!!!!!!!! :shock:
LOL....
Wichita Falls TX? I go down there to PPG at least once a week.. :lol: |
