9 speed tricks ;-).
Hey, most guys know you can use the "Phantom" gear (Low gear High range) as a place to go instead of having to range shift down every time you get a bit slowed down. Bobtail you can usually be lazy and start out in "Phantom" and shift up from there. I discovered (rediscovered?) a neat trick the other day. The "distance" between low and second is actually one and a half the distance between all the other gears. I usually start out loaded in second and hit every gear but in starting a bit downhill or unloaded I was starting in third and skip shifting into fifth, then 7,8,9. Problem is the distance between two gears is a lot - but it turns out the "Phantom" gear is really about gear four and a half, so you can shift much smoother by starting in third, then "Phantom" (4.5), then 6,7,8,9 8) .
I have never heard of this "phantom" gear. What are you talking about?
Originally Posted by NascarFan
In a 9 speed you have Lo, 1, 2, 3, 4[...]
The famous Greyhound Scenicruisers used to have a "phantom" gear. The initially used a 3 speed + 2 speed transmission with two detroit diesel 4-71NA engines tied together with a fluid coupling. In 3 high, the speed was governed but if the driver brought the shift lever just out of gear, between 3 high and neutral, the speed governor could be bypassed. Eventually Greyhound replaced the double 4-71NA engines / 3 + 2 transmissions (they turned out to be rather unreliable) with a single 8V-71NA engine and 4 speed spicer transmission. |
You guy's are gonna be sooo excited, when you learn how to shift... HOW to really pull... some weight.... :shock: .... :lol:
Thank the deity(ies) of you choice I've only been driving two years and have never had to deal with the weird transmissions they used to run in the good (bad?) old days :shock: . I worship power steering, air operated range shifts, air conditioning, air suspensions, and electronic engine controls 8) .
| All times are GMT -12. The time now is 01:27 AM. |
