+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 28
Thread: Another GPS Question (Sort of)
    devildice's Avatar
    devildice is offline Senior Board Member devildice is on the right path.  You could probably safely loan them a quarter.
    Sep 2006
    San Antonio, Texas
    2,015
    Default Another GPS Question (Sort of)
    OK all you electronic experts out there I have a question.
    I run MS S&T on my Toshiba "Satellite" laptop......the factory speaker just ain't cutting it. Even with the volume on high, it is very difficult to hear the spoken directions with road noise, etc.
    So, I plugged in a pair of ordinary Walkman type speakers into the jack that is normally used for headphones......volume on high and still can barely hear the spoken directions from the GPS. ALL other programs/applications come through loud and clear (in fact too loud on high).
    I even bought a pair of so called "laptop speakers", the ones that plug into the USB port. Again, same issue as before. ALL other programs/applications are loud and clear but the GPS is not.
    Any ideas on how to correct this.....if it is even possible??????
  2. #2
    Malaki86's Avatar
    Malaki86 is offline Senior Board Member Malaki86 is a trusted source of information and would probably pick up your dry cleaning. Malaki86 is a trusted source of information and would probably pick up your dry cleaning. Malaki86 is a trusted source of information and would probably pick up your dry cleaning.
    Aug 2004
    West Virginia
    3,878
    I bought a $20 set of amplified speakers from Target and it works out great for me. You don't need anything great, just something with some true amplification. If you've got an inverter in the truck, find a set that plugs into the power, or get a small inverter (cig lighter style) to power them.
    Streets & Trips is bad on the volume level of the spoken directions however. You might check on www.gpspassion.com and do a search there. I think I've seen it mentioned on how to overcome the problem with it.
    Wanna play a couple online games that are absolutely free? These are the games I play on a very regular basis:
    Battle of the West & Mobs Law
  3. #3
    terrylamar is offline Senior Board Member terrylamar is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Apr 2006
    Austin, TX
    1,565
    1. In Control Panel, open Sounds and Audio Devices.
    2. Click the Audio tab.
    3. Under Sound playback, click Volume.
    4. Move the volume and wave sliders to the top.
    Terry L. Davis
    ATS Specialized
    Truck # 72426
  4. #4
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Quote Originally Posted by terrylamar
    tried that.....and when I run the test to hear the volume, sounds great....however, during the actual use, no dice
  5. #5
    Rev.Vassago is offline Guest Board Icon Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name. Rev.Vassago is well-known and should trademark his/her name.
    Apr 2006
    The other side of the coin
    9,411
    Default Re: Another GPS Question (Sort of)
    Quote Originally Posted by devildice
    A fix that I did with my computer was to get one of those little FM transmitters from Wal Mart (they are in the automotive dept - the one I use is white, and cost about $10.)
    Plug it into the speaker jack on the computer, and TURN THE COMPUTER VOLUME DOWN (if you don't, the sound is all distorted). Then just set you FM radio to the correct station, and your computer will come through the truck's stereo. :wink:
  6. #6
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Quote Originally Posted by Rev.Vassago
    Thanks Rev,
    I'm gonna have to head over to Wally world and see if I can get one of them there gadgets
    is there a particular name brand to look for?
  7. #7
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    BTW....with that device using the radio, that means I have to sacrifice listening to the radio then?
  8. #8
    Apr 2006
    9,411
    Yes - you cannot use the station you are broadcasting the computer on.
    It is similar to this one:
    http://www.walmart.com/catalog/produ...uct_id=4694330
  9. #9
    Toothpick is offline Board Regular Toothpick is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Nov 2004
    321
    You never did mention which version of Streets & Trips you are running, or did I miss it? Anyway, when I ran the 2006 version, it was barely audible. However, when I switched to the 2007 version, it was loud and clear, with out an FM modulator or amplified speakers. Even with the satellite radio on. Microsoft beefed up their text to speech engine in the 2007 version and the volume, at least on my computer, comes in loud and clear.
  10. #10
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Quote Originally Posted by Toothpick
    I'm running MS S&T 2007 w/gps on a Toshiba "Satellite" laptop.
  11. #11
    Mtc_Is_Hell is offline Board Regular Mtc_Is_Hell is an unknown poster at this point.  Don't let him/her around power tools just yet.
    Aug 2006
    Granite City, Il
    217
    I have a Magellan gps.. Cost me 550 with tax.. Ok so I seen that program at best buy for 120 bucks. I also have the same laptop as you, Speakers do suck btw, I use headphones just to hear the movies over the truck idle. But other then this issue how good is that program and where do you mount or put your laptop?>
  12. #12
    Aug 2006
    Granite City, Il
    217
    Dont everyone reply at once plz.
  13. #13
    Malaki86's Avatar
    Aug 2004
    West Virginia
    3,878
    Quote Originally Posted by Mtc_Is_Hell
    S & T 2007 is a gooed program. Well worth the cost. Also, if you have a GPS receiver (that the laptop recognizes), you can use it, instead of buying the full version with a new receiver.
    I kept my laptop in the sleeper. I have a 7" touchscreen monitor & an addon keyboard that I use in the cab.
  14. #14
    Apr 2006
    9,411
    Quote Originally Posted by Malaki86
    My problem seems to be that I go through GPS receivers. I just bought my fourth one in a year and a half, at $100 a pop. :shock:
  15. #15
    Malaki86's Avatar
    Aug 2004
    West Virginia
    3,878
    Ouch... I'm still on the receiver that came with S & T 2005 - and I use that same receiver for CoPilot & Delorme, as well.
  16. #16
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Rev,
    Maybe if you stop trying to use it as a pc mouse and leave it on the dash as the GPS receiver it was designed to be
  17. #17
    Apr 2006
    9,411
    That's my problem - it doesn't pick up a decent signal on the dash, so I have it mounted outside. I have a knack for getting the USB port stuck in the door jamb, thereby crushing it. :sad:
  18. #18
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    That's strange that you are not getting a decent signal on the dash as they are designed to "supposedly" work that way.
  19. #19
    Apr 2006
    9,411
    I'm guessing it is due to the fact that I drive a 379. Hardly any slope to the windshield, and a metal visor right above it.
    When I did have it on my dash, it would lose its signal, or not "grab" enough satellites to get a decent signal.
  20. #20
    devildice's Avatar
    Sep 2006
    San Antonio, Texas
    2,015
    Oh I see.....simple solution then....buy a different truck.......just think, after about a 1,000 gps receivers, it will pay for itself
+ Reply to Thread
