I just bought a Garmin Street Pilot 7200 with a GXM antenna, from Amazon.com: http://www.amazon.com/Garmin-Streetp...&s=electronics
I'm a proud Werner driver, but unfortunately sometimes our directions from Werner are simply put: retarded.
A couple weeks ago I had a consignee near a Best Buy, so I took a short walk over to see what sort of GPS units they had - I ended up dropping $1150 on a Garmin "Nuvi" this little thing kicked butt! it had truck routing built in, touch screen display so it was easy to navagate on-the-fly - also I could find a truck stop, or somewhere to rest with a couple clicks on the Nuvi's screen... BUT: I found this other GPS that Garmin makes called the "7200" it gets XM radio, has a 7" screen, and it gets weather and traffic updates for where I'm at also. So I returned the Nuvi. The 7200 is a bit pricey at $1200 but I think it'll be well worth it - Garmin GPS units are much better than Streets and trips, or other GPS units you can plug into a laptop... just check 'em out you'll be glad you did.
Ant ~
