T660 ISX idle shutdown override
This has been bugging me for a while yet, and I haven't found an answer to this dilemma. I have a 2012 KW T660 with a Cummins ISX. I haven't been able to get the truck to idle beyond five minutes. I tried the clutch, the accelerator, and bumping the rpm's up via the cruise control. So far, those things will extend the idle for five more minutes, but not all night long. Since it's a company truck, I can't just take it to a dealer to have this fixed. Do any of y'all know the proper way to do this?
Reprogram the idle settings on the ECM.
leave yellow button pushed in and use trailer brakes for parking
i drive 2010 kw t408 (your 600 series) 550 isx and clutch over rides shut down but otherwise yep 5minutes
As for the ECM, I do plan on asking the shop foreman about that whenever I'm there during first shift. If their programming software can communicate with the engine, they might be able to allow for override, since the truck doesn't have an APU. I'm just glad I got it after summer was over, since I don't need A/C at night. It does have an Espar heater, though, which works rather well. We also don't really need to worry about fuel gelling up often and we keep anti-gel on hand during the winter, so that shouldn't be a problem either. |
The company I work for just started getting new 2012 trucks with the ISX in them and one of the drivers told me his won't idle past 5 mins. unless outside temps are above something like 80 or below 30.
I did figure out something about it this week. The cruise control must be OFF for this to work. For our trucks, I don't know the exact temperature setting, but this worked when it was 71 degrees, so I'm guessing that it's from 70 and above. I don't know how cold it has to be, but I suspect either 20 or 30 (since we do have Espar heaters). Just press the clutch when the check engine light flashes, and that'll get it to work at those temps. I'll update whenever it gets colder. |
