patching small hole in sidewall tire
has anyone had any luck patching a small hole in the sidewall of a tire ?
If DOT sees it, they won't be happy.
If the "wound" isn't too severe, a tire shop can do what's called a "section repair", where they patch the hole on the inside of the tire and vulcanize the outside.
These repairs are usually accompanied by a blue triangle shaped marker glued to the outside of the tire next to the repair, which identifies the repair as being made by a certified tire shop, in the event that a DOT inspection is performed. |
Piss on DOT. Since when do they look at the inside of a tire? Just please don't run it on your tractor.
well i dont know anything about vulcanizing the outside of the tire. the reason for the question posted was because i have fixed 2 such holes in the last 1-2 years. & they are still holding 100%. they are on the trailer of my flat. all tire shops would not even try to fix. said no way to fix it. they were tires with less than 1000 miles on them. the last one was 2 days old. just wondering if anyone had a betterr way to repair small holes other than my method.. my method consist of....
clean area to be patched, apply glue, let set for 3-5 min apply patch, apply more glue, let set 3-5 min, apply another patch directly over 1st one. wait 1 hour & apply hight temp silicone 1/4- 1/2 inch thick over patch area & applied 1 inch diameter more than patch. the glue was blue in color & bought at truckpro along with patches. i wanted to make sure this would work before i mentioned it. & since i am putting new tires on after 118,000 miles with the patches still on & still holding.. i guess it passsed the test.. or at least mine. also i have a spread & everyone know what the tires look like when your in a tight turn bind. & i'm in plenty of those every day. tires still held up twisting & all. |
i doo want to say one hole was a pin hole the other a lil bigger.
Patching the tire from the inside is much more effective... and doesn't require a silicone mask to cover. Sidewall repair is frowned on in the industry because sidewall punctures often break sidewall cords leading to zipper cuts and blowout. ...isn't silicone supposed to have a negative reaction to tire rubber? |
Oh God, one of the people who scare the sh1tt outa ya when they have a blow out as you pass them or leave Gators all over the road.
Buy good tires !!!!!!!!!! |
