THERMO KING UNIT ALARM CODES
This list is ordered by SEVERITY and numerically.
TAKE IMMEDIATE ACTION: 09--High Evaporator Temp > Unit Shut Down To prevent damage, repair immediately 10--High Discharge Pressure > Unit Shut Down To prevent damage, clear and restart, if reoccurs repair immediately 12--Sensor Shutdown > Unit Shut Down to prevent damage, repair immediately 17--Engine Failed to crank >Clear Alarm, preform manual start in continuous mode, repair as required 18--High Engine Water Temp > Check belts and coolant level, correct 19-- Low Engine Oil Pressure >Check oil level, correct, clear alarm, repair as required 20--Engine Failed to Start > Check fuel level, preform manual start in (Cycle Sentry) continuous mode, repair as required 23--Cooling Cycle Fault > Unit shut down to prevent damage, repair immediately 24--Heating Cycle Fault > Unit shut down to prevent damage, repair immediately 25--Alternator Check > Press "Amps" to check alternator charging rate, repair as required 30--Damper Stuck Closed > Damper is Stuck closed, repair immediately 32--Refrigeration Capacity Low >Repair immediately if leak is accessible, Off load a.s.a.p./ refill freon temporary until off loaded. 35--Run Relay Circuit > Check emergency switch position if present, repair as required 36--Electric Motor Failed to run >Check standby source of power, correct immediately 38--Electric Phase Reversed > Standby power phased wrong, correct immediately 44--Fuel System check > check fuel level in fuel tank, add as required , clear code, prime, restart 47--Remote sensor shutdown > multi-temp zone sensor failed, zone shut down , monitor temp & repair as required 48--Check Belts or Clutch > Drive belts or clutch slipping, repair as required 60--Boost Circuit > Unit operating without boost capacitors, repair as required 62--Ampmeter Out of Cal Range>ampmeter inaccurate, repair as required 63--Engine Stop-Reason Unknown>Check fuel tank level, try manual start, repair as required 66--Low Engine Oil level >check engine oil level, add as needed 74--Computer reverted to default settings> Unit has reset, control temp may not be as required, check, repair before reloading. 75--Computer RAM >computer defective, repair before loading 76--computer EPROM >computer defective, repair before loading 77--computer EPROM checksum >computer defective, repair before loading 78--Data Log EPROM >computer defective, repair before loading 82--High Compressor Temp shutdown>compressor shutdown to prevent damage, repair as required 111--Computer not Configured Correctly>computer not configured for this unit type, repair as required before loading 114--Multiple Critical Alarms, Can not run> check & note all codes, repair as required. __________________________________________________ __________ |
The only problem is you will get 23 ALOT when hauling Ice Cream across the desert in the middle of the summer. When it is 120 outside and you need -20 in the trailer no unit made will get it there and the unit will scream 23 at you all the time. Reset it and move on.
