Results 1 to 2 of 2
Thread: Does excess idling cause carbon buildup?
    Douglas is offline Board Regular
    Jan 2005
    Tifton, GA
    278
    Default Does excess idling cause carbon buildup?
    If a truck spends most of the day moving around 3-5 mph, so that the engine is always at idle RPM (around 700 RPMs) for hours and hours a day, will this result in carbon being built up? The 06' International 4200 truck I drive is a street sweeper, and it's getting to where the truck is every weak; it doesn't pick up speed like it used to (for driving back and forth when not sweeping) and will hardly even accelerate at all if going up a hill. If this is a result of carbon being built up, is there a way to prevent it? (They have us get out on the open road at 55 mph once a week, and it seems to help some.)
    Be calm in the face of all common disgraces and know what they're doin' it for - G. Lightfoot
  2. #2
    Jan 2010
    Ottawa Valley Ontario, Canada
    195
    Yes I have the same problem with both of our 4200's I'm going to take the muffler off of the 2003 soon to seeifthat helps, I've cleaned the carbon out of the rest of the erg system so I figure that's the next step.
    You may try taking the erg valve out and cleaning it with carb cleaner, the valve is on the top of the engine beside the oil filter it has 2 small bolts holding in and a couple of small pry bars will be needed to bring it out.
    Try this website for more help: Diesel Forum - TheDieselStop.com
    This may help too: http://m.youtube.com/index?desktop_u...?v=f5ToASEao8U
  3. This ad will disappear if you login
