When I started my truck a couple days ago to drive it to the fab shop, I had no power steering. In fact, it felt like I had worse than no power steering. By the time I idled down my drive to my house (maybe 400 feet at most) the steering improved but it was not like it should be. I popped the hood to have a look and there was fluid blown all over the place around the power steering pump. I checked the reservoir and it had fluid. I had my father hop (well, at 68 he doesn’t hop anymore, but you get the idea) in the truck and turn the wheel while I watched the power steering pump and there was no leak and he said the steering felt fine to him. After driving the truck up to the shop (15 miles), I checked again and the reservoir was dry. I added the specified Dexron III Mercon ATF to the reservoir and started the truck and had my father turn the wheel again. A small amount of clear fluid (just a few drops) appeared on one of the hoses, but that was it and the steering worked well. The clear fluid smelled like brake fluid to me, not automatic trannny fluid. I continued to work the wheel back and forth and no more fluid appears to be leaking.
Any idea as to what the heck happened and why? Because it was pretty cold (for here... 18 degrees) and the truck hadn’t been started in a few days, I’m wondering if a small amount of water didn’t settle in the pump or a line somewhere and prevent the thing from working properly. I’m also wondering if some shop the truck has been to recently might have put brake fluid in the system which could have caused the seals to do unusual things.
I’m stumped as usual with this truck and its gremlins and I’m open to suggestions.
