Results 1 to 6 of 6
Thread: How many driven wheels?
    Drivetrain is offline Rookie
    Apr 2011
    2
    Default How many driven wheels?
    Ok, on your typical tandem axle tractor that has 4 sets of two wheels, how many are driven. It's been a while since I've been on a rig, but I remember an axle lock switch and also remember peeking underneath the rear and seeing two differentials. If you get stuck and start spinning, do both F and R and L and R all spin?
    Thanks
  2. #2
    Jan 2010
    Ottawa Valley Ontario, Canada
    195
    Ask Mackman
    It depends on the setup of the truck, if it has differential locks on both axles and an interaxle lock then yes all will spin. Without a diff. lock one side left or right will spin and without an interaxle lock one axle could spin.
  3. #3
    Windwalker is offline Board Icon
    Oct 2005
    Been there and gone...
    6,287
    Quote Originally Posted by classictruckman View Post
    Ask Mackman
    I agree with you except for one point. Anytime I've found myself spinning, it's been in trying to take off. Nearly always at very low speeds. And, when I did, it was most generally opposite corners that would spin. Front left and rear right, or front right and rear left. One more note.
    Absolutely, never, NEVER, NEVER lock the interaxle differential when one wheel is spinning. Not while any wheels are spinning. If you have one set of duals hanging over a pothole and spinning, hold the brake for a good 20 to 30 seconds to make sure that no wheels are turning when you engage the differential lock. If you still have a wheel spinning when you flip the switch, you will generate multiple fragments inside the differential housings, and the repair will cost thousands. If you're moving, release the throttle, press in the clutch, and flip the switch. Then let the clutch out and apply throttle.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  4. #4
    mike in idaho is offline Rookie
    Nov 2010
    orofino, idaho
    21
    Summer before last I was leaving the local paper mill and came by this brand new pair of drivers in a bobtail swift tractor, they had missed the turn into the yard and had pulled into a pot-holed wide spot to flip a u-turn. The truck was parked with two opposite rear wheels high and dry, over two potholes. One of the guys was outside watching his partner, trying this gear and that, spinning the two sets of airborne duals. I should have stopped to show them what to do, but I was laughing so hard I just couldn't.
  5. #5
    Copperhead's Avatar
    Copperhead is offline Board Regular
    Oct 2007
    Kellogg, IA
    406
    Good case for lockers on the drive axle. Of course, there are few company drivers like those at the mega carriers that would be able to use them properly without destroying a drive axle. But you won't hang up and not have any traction!
    A superior driver uses superior judgement to avoid situations which require superior skill.
  6. #6
    willismith is offline Rookie
    Jul 2011
    13
    Thumbs up Re
    Hi Windwalker, I am agree, and thanks for sharing it. It is helpful to me also.
    Quote Originally Posted by Windwalker View Post
    => Defensive Driving In Houston | defensive driving class nj
    ✔ 100% customer satisfaction guaranteed | ◭ Same day certification
