Results 1 to 6 of 6
Thread: Chasing a Short - 2003 Freightliner XL Classic - Wire 28d
    GLD
    GLD is offline Rookie
    May 2008
    Tulsa
    2
    Default Chasing a Short - 2003 Freightliner XL Classic - Wire 28d
    Greetings,
    Have a short in whatever circuit is served by Wire 28d, which goes into the third circuit breaker from the bottom in the breaker panel.
    1) Do you know where I can find a wiring diagram?
    or
    2) can you tell me where wire 28d goes?
    THANK YOU !!
  2. #2
    chris1 is offline Senior Board Member
    Jan 2009
    546
    Give vin# to freightliner and they'll give you the correct wireing diagram.
  3. #3
    Jan 2010
    Ottawa Valley Ontario, Canada
    195
    I've heard that freightliners(especially those built in the last 10 years) are the worst for wires being run through bad spots and over sharp edges.
    I have chased alot of short circuits but usually they turn out to be a bad relay.
  4. #4
    YerDaddy's Avatar
    YerDaddy is offline Board Regular
    Mar 2008
    @ my keyboard
    225
    28D goes from breaker to driving light relay.
    You might wanna sign up here> https://secure.prd.freightliner.com (gotta use Internet Explorer)
  5. #5
    Windwalker is offline Board Icon
    Oct 2005
    Been there and gone...
    6,287
    Quote Originally Posted by YerDaddy View Post
    Really? I don't have any problem with Firefox or Chromium. Works just fine.
    I had a Freightliner 2000 Classic XL, and the wiring was a RAT'S NEST. At least, back in the '90s, Kenworth and Pete were lacing their cables up and you could find what you were looking for. It looks like Freightliner simply pulls in the wires, one at a time, and leaves them where they end up. They can shake and vibrate while you're driving and rub through or even break off, then try to find the problem and fix it. Mine looked nice, pulled well, and got reasonable fuel economy, but the wiring is enough to turn a body off towards Freightliner. They're inviting problems with a lack of quality, as far as I'm concerned. And, using the wiring as an example, it doesn't speak well for the rest of Freightliner's quality.
    Destroy the cities...
    and they will rebuild them.
    Destroy the farms...
    The bill has come due.
  6. #6
    LBF's Avatar
    LBF
    LBF is offline Member
    Jul 2009
    Ontario, Canada
    105
    start here: www.AccessFreightliner.com
    if you aren't already a registered user of the above link
    Lightblue Freightshaker
    Ontario, Canada
Tags for this Thread
