While on the subject of tires I've often wondered if there is any advantage (fuel mileage wise) of 22.5 tires versus 24.5 rubber?
"Looks like a legend and an outta work bum look a lotta like Daddy," Little Enos Burdette.
Hook 'em Horns!!
"Life is hard. It's harder if you're stupid." John Wayne
"Talk to me Goose".
"What we're dealin' with here, is a complete lack of respect for the law," Sheriff Buford T. Justice.
Friends don't let friends drive for C.R. England!
Yes there is an mpg advantage using LP 22.5 vs 24.5. First, LP 22.5, in most cases, have a lower rolling resistance than 24.5 tires. The selection of fuel efficient tires in 22.5 far excedes the selection in 24.5. While it is true, that at the same speed, with the same gearing, the 24.5 will allow the engine to operate at a slightly lower RPM and give the appearance of then getting better fuel mileage, you have to take into account the rolling resistance of the tires. Most 24.5 tires will have rolling resistance figures of 155 or even much higher, whereas fuel efficient LP 22.5 tires have rolling resistance of 110 or lower. The Michelin XDA Energy LP 22.5 drive tire has a rolling resistance somewhere around 90.
I guess it is just a matter of personal choice. Some like tall rubber while others are not so inclined. I like using LP 22.5 for the vast selection available and the decreased overall cost for tires and fuel savings. If one needs to replace a rim, 22.5 rims are easier, cheaper to come by than 24.5 rims since there are so many more of them out there. If it is all about running a certain speed and keeping the engine RPM lower, I would rather do that thru gearing than using taller rubber.
A superior driver uses superior judgement to avoid situations which require superior skill.
good info here http://www.bridgestonetrucktires.com...ctor_specs.asp
I am considering going back to l.p.22.5 from my current standard22.5 jsut to lower the height & get more stable a ride.
| Trucking
Companies | Trucking
Job Search | Online
Job Application | Trucking
Links | Truck Drivers
Message Board | Contact
Us | Site Map
