Results 1 to 5 of 5
Thread: International CabOver
    marq is offline Rookie
    Jul 2010
    3
    Default International CabOver
    I have a cummins engine and when I am under a trailer I lose power going up hills and now it will only run 66 miles an hour. The speedometer is not working now when it once was. Any ideas what is wrong?
  2. #2
    Shnerdly's Avatar
    Shnerdly is offline Member
    Dec 2008
    The Frozen Tundra of Minnesota
    85
    My first thought would be a fuel filter or a fuel line collapsing inside.
    Colt: The original point and click interface.
    Gun Control isn't about guns, It's about Control.
  3. #3
    Jul 2010
    3
    Default speedometer
    you got any thoughts about the speedometer not working
  4. #4
    Shnerdly's Avatar
    Dec 2008
    85
    It could be any number of things.
    Bad Ground on the Speedo head or a bad speedo head.
    Broken wire.
    Bad sender at the Transmission.
  5. #5
    Kranky's Avatar
    Kranky is offline Senior Board Member
    Jun 2006
    Wisconsin
    1,108
    If the Cummins is an electronically controlled engine, then I would suspect a problem with the VSS (vehicle speed sensor) or it's associated wiring.
    A problem with the VSS will cause the ECM to go into "limp mode" (HP derate) and will also cause the speedo to quit working, as there is no vehicle speed data being sent to the ECM.
    The VSS is located at the transmission tailshaft, right where the old type speedometer cable would have been if it was a mechanical type setup.
