Results 1 to 4 of 4
Thread: Truck Sputters and Cuts Back in 10th Gear?
    Hawkjr's Avatar
    Hawkjr is offline Senior Board Member
    Mar 2008
    In The Granny Lane Doing 60!!
    649
    Default Truck Sputters and Cuts Back in 10th Gear?
    My POS day cab Volvo is having a serious problem and none of the idiots in the shop can figure what it is.. Going down the road in 9th or 10th the truck starts cutting back, sometimes dropping 5mph then going back up to speed.. No hills or anything, on flat ground it does this.. We changed the fuel filter and its still doing it.. someone suggest it could be the ECU.. Any suggestions??
  2. #2
    firebird_1252 is offline Board Regular
    Feb 2009
    449
    volvo motor? i used to drive one and it would do the same thing.. no spudder.. it'd slow down 10-15mph on flat ground then pick back up and do it all over again.. dealer found no problems.
  3. #3
    Jackrabbit379 is offline Board Icon
    Oct 2005
    Wichita Falls,Tx
    7,100
    Fuel pump itself?
  4. #4
    Shnerdly's Avatar
    Shnerdly is offline Member
    Dec 2008
    The Frozen Tundra of Minnesota
    85
    I don't know what year your truck is or what engine you have but I was driving an 07 KW with an ISX in it last year. It had a random loss of power and would sometimes smoke like an old Mack when pulling a hill. After we did everything else, we took it to Cummins and they said it was the Variable Geometry Turbo ($1800). I didn't think that could be right but they changed the turbo when it came in two days later and it solved the problem completely.
    Colt: The original point and click interface.
    Gun Control isn't about guns, It's about Control.
