Results 1 to 5 of 5
Thread: fuel temp sensor
    heavyhaulerss's Avatar
    Jan 2007
    north alabama
    1,189
    Default fuel temp sensor
    had yellow light come on dash (engine warning) found out it is fuel temp sensor. is it important to replace asap ? what affect will it have if not replaced. hope to finish my loads for the week. so far I have not noticed any difference in engine performance. also can I just replace myself or does it need to have anything reprogrammed into the ecm? called freightliner dealer. can order part & have in a day.
  2. #2
    Jan 2007
    north alabama
    1,189
    Quote Originally Posted by heavyhaulerss View Post
    This is on ser 60 det
  3. #3
    Oct 2006
    Nb
    794
    It may affect fuel mileage. Check for a 2-wire sensor at the fuel filter header. Key switch off, you just thread it out and thread new one back in; if it was the problem, the light should go out when you key back on. Engine may start hard after if you lose too much fuel ( have the new one ready to plug the hole ).
  4. #4
    Jan 2007
    north alabama
    1,189
    got the new sensor. dealer had in stock. location of sensor is on back of fuel pump. will change today. sat. I dont have the typical fule filters, so I am not sure about any fuel filter header. I have the davco sys.
    thanks for the reply.
  5. #5
    Jan 2007
    north alabama
    1,189
    That was one of the easiest fixes. 3/4 wrench. dripped about a tbls of diesel out & then stopped, screwed new sensor in.
