I'm having a problem with shocks that are only a few months old leaking oil. They are Gabriel GasSLX shocks. I changed them in August thereabouts. The dealer says it is not a warrantable problem because it is "misting" which is normal, but I've had Gabriel shocks that last 2+ years without leaking any oil.
I had to change one shock that seized, but could only get a regular Gabriel shock, which is the same style shock that lasted several years. This one has started to leak after 4 weeks!
Has Gabriel really gone downhill that much over the past while?
Problem is I'm sure there's regulations out there that prohibit leaking shocks, I know the truck will fail a safety. Will it fail a level 1 with shocks like this?
